Forward detent, question about adjusting RPM |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3359 |
Posted: July-08-2024 at 8:45am |
In neutral the throttle Cable should be adjusted so its putting light positive pressure against the carb's idle stop. I suspect your helm is holding the throttle up from the idle stop.
River Rat to Mole |
classicM
Newbie Joined: July-01-2024 Location: 12814 Status: Offline Points: 2 |
Just putting the engine in forward is about 250 RPMs so the boat stalls. Can anyone give a reference as to what it should be? Neutral gives about 800. Reverse doesn't have an issue, but I don't recall off the top of my head what those RPMs are. 351 Ford PCM. I couldn't post this in maintenance for some reason it said I wasn't allowed.
