Manifold drain cocks |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2958 |
Posted: Today at 4:34pm |
Mark:
On my 2 previouis boats with the 5.8 Small Block Ford, I used these: I purchased them from McMaster-Carr: https://www.mcmaster.com/products/petcocks/drainage-valves-5/ I had one for each side of the block and one for the U-Bend (J-Bend) in the raw water system. I also replaced the cast iron plugs with brass plugs at the ends of the exhaust manifolds/risers. JQ |
ultrarunner
Platinum Member Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1838 |
For those that have done it, can I see a pic of your setup? Thanks, Mark
