Adhesive for Nautolex flooring |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5787 |
Posted: December-13-2024 at 12:18am |
Still need it Tim, just drop it in the mail when you get a chance. I’m still a month away from getting the short block back
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21189 |
She can’t stay retired forever…
It helps that my panels were not installed- so it was fairly easy working with them on a clean, flat surface. I did contact cement on the faces and then wrapped the edges and stapled underneath. Installed later. I still have your pulley in the bed of my truck, btw- hope I didn’t miss the engine build window yet! |
81nautique
That’s probably a better option if I can talk my partner out of boat building retirement to lend a second set of hands. Thanks |
Looks like a good choice if you want to be able to reposition a little as you go. Mine were all small, flat panels- so I used contact adhesive.
81nautique
What are you guys using for adhesive for Nautolex flooring. Looking at Henry’s # 356?
