  New Posts New Posts RSS Feed - Threaded block drain plugs
2001SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2001SAN Quote  Post ReplyReply Direct Link To This Post Topic: Threaded block drain plugs
    Posted: Yesterday at 2:46am
I had the same issue with the drain plug on my v drive. When I first winterised the plug literally fell out there was so little thread left. Ran the tap up it as suggested and been fine ever since.
A little knowledge is a dangerous thing...
2001 Super Air Nautique
1989 Fairline Corniche 31
www.bannrivercruises.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-10-2025 at 8:15am
You should read the thread in the link below
Then after that, run a 1/4 NPT tap in the holes, whether you think it'll work or not Wink
It's worked for lots of people with the same issue.
1985 Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1985 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-09-2025 at 11:58pm
At the end of last year, when I pulled the two drain plugs out of the block (1/4" brass) to winterize the engine, there weren't a whole lotta threads left in the block. I've already replaced the elbow from the water pump to the thermostat housing for this very same issue.
Any ideas on how to fix this? Contemplating drilling out the diameter of the hole, tapping a 3/8" NPT hole, inserting a 3/8" x 1/4" NPT brass adapter, and loctiting them into the block. This would still allow the use of the 1/4" NPT plugs for draining the block at the end of the season.
Please let me know how you have fixed this issue.
Thanks!!
Brian
1985 Ski Nautique
"I've spent half of my money on women, liquor, and boats. The other half I wasted."
