351w acting like a woman |
92cc ![]() Newbie ![]() Joined: December-11-2006 Location: United States Status: Offline Points: 34 |
![]() ![]() ![]() ![]() ![]() Posted: December-29-2006 at 9:37am |
Test,don't guess,install a fuel pressure gauge in line to the carb and duplicate the problem,check fuel pressure while it is running poor,if the pressure did not drop,it is not a fuel problem,although could still be fuel quality.
JoeinNY ![]() Grand Poobah ![]() ![]() Joined: October-19-2005 Location: United States Status: Offline Points: 5698 |
Waterdog is moving in the right direction with the vent, if it seems like a fuel problem it probably is, if the gas cap trick doesnt work check any fuel filters condition of the lines etc. Possible to have some crud floating around your float bowls causeing this type of problem as well, in which case a rebuild would be in order. I have seen friends replace entire ignition systems in the past to fix a gummed up carb that could be rebuilt for 15 bucks in parts...
-Joe. |
Waterdog ![]() Grand Poobah ![]() ![]() Joined: April-27-2006 Location: United States Status: Offline Points: 2020 |
Make sure the fuel tank vent is open. To check it when the engine stumbles open the gas cap.When it happened to me I threw everything I could think of at it. After 2 months of changing parts, it happened with a freind , he opened the gas cap & it ran perfect! I coulda kissed him on the lips. BUT I DIDN'T. The beers were on me for the rest of the trip though. Dam dirt dobbers get everywhere.
Marty ![]() Newbie ![]() Joined: August-24-2006 Status: Offline Points: 13 |
87, FN, 351 w 250 hours standard stuff. we baught new W from factory in 2000
points, mallory dist. someone told me it was the fuel pump, changed that today. took it out ran great, then i slowed down started doing the same thing not quite as bad, maybe my imagination. tomorrow i will try airing out the dist.thnx i'll get back
63 Skier ![]() Grand Poobah ![]() ![]() Joined: October-06-2006 Location: Concord, NH Status: Online Points: 4288 |
I had a strange one in a jet boat last year that someone else solved for me. Problem was condensation in the distributor. Boat ran great for 15-20 minutes, then sputtered below 2000 rpms though it would still run at higher speeds. Turns out the water sits in the bottom of the distributor until it warms up, then vaporizes and causes mis-fires. Stop the engine and it condenses again. Fix is to open up the distributor and either let it air out for a day or more or use a hair dryer to try to dry it out, I did both and problem solved. Not sure this applies but thought I'd mention it.
eric lavine ![]() Grand Poobah ![]() Joined: August-13-2006 Location: United States Status: Offline Points: 13413 |
do you have points and condensor? please describe in more detail, boat, year engine etc....
made it out apr.10 miles off fort laud. then back, had plenty of fuel. started acting like it was out of gas - never stopped runing, it would stall if i gave it gas. ran like this for apr.2 miles, them like a switch was turn on real smooth @ 4000 rpms for apr 2 miles then died again. changed the coil, whet out did good for a while, now back to the same this. guess it was't the coil, any ideas ?
