mpi conversion |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3365 |
Posted: December-18-2006 at 6:58am |
Found your problem |
River Rat to Mole |
doug e
Newbie Joined: October-24-2006 Location: United States Status: Offline Points: 25 |
yea, I think my carb is a rodchester quadro-jet 850(too big). Thanks for all your help I think a new carb is the way to go!
Cheap thrill fishing team
boat dr
Doug,Electronic Fuel Injection,is a mechanical way to induct fuel and air into an engine.The two popular ways are Multi Port Injection and Throttle Body Injection.One uses one injector for each cyl, a more complicated but better way ,TBI uses a throttle body and common injectors ,usualy 2 to accomplish fuel distribution.Its just a high tech carb,with no fuel bowl.
Sounds like a carb problem ,a new carb would be far cheaper,S/B Ford 302 ,mine,loves the Holley 450 CFM, will idle for hours at 500 rpms.............boat dr |
doug e
I spend hours at a time live bait fishing at very low idle and it seems that the carb. motor has a hard time at that. will efi or mpi help for this And is there a differance between efi and mpi
Thanks |
boat dr
Doug, Sumitt has several kits to convert to MPI tho very pricey.Accel offers a complete kit for 2595.99,s/b Chevy; 2795.99 s/b Ford. Includes ECM,pump,manifold,all parts to make your carb go away. Sounds kinda pricey to give you instant start,fuel usage wont change much.
Holley has a kit also,but they have a lot of gotta haves with their system. go to Summit.com and look at what is available..............boat dr |
doug e
Can anyone recomend the best way to convert to mpi on a carbed 2005 chevy 350
