  New Posts New Posts RSS Feed - temp
temp
curtisco24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote curtisco24 Quote  Post ReplyReply Direct Link To This Post Topic: temp
    Posted: January-01-2007 at 7:30pm
thanks for the advice
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2006 at 7:17pm
Matt,if the engine had a blown head gasket or a cracked block(improper winterization)it would still run hot even without the thermostat.I agree with nutty,buy a oem thermstat,i think it is a 140 degree,new Autolite plugs timing set to specs and go from there............ boat dr
Post Options Post Options   Thanks (0) Thanks(0)   Quote curtisco24 Quote  Post ReplyReply Direct Link To This Post Posted: December-31-2006 at 12:51am
boat was not bought new. However, he just bought it recently. I was wondering if the removed thermostat was done to hide bigger problems such as the boat running hot?
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2006 at 7:53am
Someone has obviously removed the thermostat. Perhaps it failed to open or was obstructed and instead of replacing it they decided to remove it. And perhaps the same person advanced the timing in hopes to gain back some performance that was lost by running the engine too cold. Your friend didn't buy this boat new, right? Tell him/her to install a new thermostat, set the timing, maybe change the plugs and go from there.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
Post Options Post Options   Thanks (0) Thanks(0)   Quote curtisco24 Quote  Post ReplyReply Direct Link To This Post Posted: December-30-2006 at 12:13am
I have a friend that bought a 2001 a while back. The boat will not run over 120 degrees and misses. When my friend checked the themostat, it was not there. Why would the thermostat be gone? Also the timing has been advanced, why would this be?
