  New Posts New Posts RSS Feed - alternator wiring
alternator wiring
advsouthwind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote advsouthwind Quote  Post ReplyReply Direct Link To This Post Topic: alternator wiring
    Posted: January-09-2007 at 5:33pm
the positive is also the larger of the studs if your clock position is different than mine and the aux. is on the diode plate across from the pos. stud
gave up sea ray life for a 77 southwind 20 project just livin the dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote advsouthwind Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 5:31pm
i have a alk6220y presto alt. with the small threaded ear at 12:00 looking at the back of the unit the positive is at 9:00 at 1:oo is the field wire at 4:00 is the aux. stud and the ground is at the bottom in a female threaded hole   i have a 78 southwind hope this helps
h2oski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote h2oski Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2007 at 1:35pm
I understand what the wires are but the alternator's markings were sandblasted off during the rebuild. I'm looking to find out which is the field terminal and which is the battery post on the alternator
ricleather
Post Options Post Options   Thanks (0) Thanks(0)   Quote advsouthwind Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2007 at 10:47pm
green-field
brown-red -aux
orange-power-positive
black-ground
on the back of the alt. there should be markings by each stud.   good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote h2oski Quote  Post ReplyReply Direct Link To This Post Posted: January-07-2007 at 12:45pm
83 351 commander and need to know how to wire alternator. Orange, red, green, and Black wires and do not know where they go ... help anyone
ricleather
