  New Posts New Posts RSS Feed - Water Pump Leaking
Water Pump Leaking
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: Water Pump Leaking
    Posted: February-19-2007 at 12:27pm
get a directional pump and not a bi-directional pump when you replace it come spring, I think skidim had the right pump at a good price when I did mine a couple of years ago.
martin 74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote martin 74 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2007 at 12:20pm
Thank you! Your well informed confirmation is a big relief. Great forum. I'm ready for spring.
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2007 at 10:29am
I wouldn't get excited about it now if it is only a small amount, like a drip now and then but come spring you'll need a new cir pump because the seal is worn out in it causing the leak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote martin 74 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2007 at 12:42am
circulation pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2007 at 9:31am
RWP or circulation pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote martin 74 Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2007 at 5:58pm
I have a Waukesha Ford 351 in my 74 Martinique and a small amount of antifreeze is leaking into the bulge. It seems to come from my water pump. Could freezing temps in my unheated garage freeze trapped water to cause my seals to leak or is it worse? I didn't run it when adding antifreeze this year.
Thanks any help is greatly appreciated.
