  New Posts New Posts RSS Feed - 78 Transom Platform
78 Transom Platform
66polyhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66polyhead Quote  Post ReplyReply Direct Link To This Post Topic: 78 Transom Platform
    Posted: July-09-2004 at 12:16am
They look good!, Thanks Trevor.
swim platform brackets
tstafford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tstafford Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2004 at 12:00am
Alloy Marine products make nice removeable brackets. # 415-892-1770
Trevor 1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 66polyhead Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2004 at 11:10pm
Correct Craft and Master Craft, and Malibu use the same mounts. Go to SkiDiM. you get a 10% discount from this site.
89 Martinique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 89 Martinique Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2004 at 6:03pm
Thanks David F! Any information you can provide is greatly appreciated.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2004 at 5:27pm
I purchased the brackets from my local Correct Craft dealer whom, I am sure, ordered from a catalog/supplier. My friends 85 Nautique uses the exact same bracket for his platform. I know I have the receipt for the brackets, but the papework is at home. Maybe the invoice will list a model/manufacturer...stay tuned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 89 Martinique Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2004 at 2:51pm
David F.
Who did you purchase the Brackets from? I have the same problem and have been looking for a set of brackets that would work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2004 at 12:45pm
I used aluminum platform brackets that have a pin release that allows me to remove two pins and the entire platform lifts up and off the portion screwed to the transom. The brackets are common and very well engineered.
yellowdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowdog Quote  Post ReplyReply Direct Link To This Post Posted: July-07-2004 at 12:40pm
How much do you need to gain?
I'm sure that you could come up a pivot or hinge system that would support the platfrom and a skier but you would only gain about a foot because of the down legs on the bracket.
It would be cleaner in the long run to cut the brackets in such a way to leave the vertical angle on the transom. Weld aluminum extensions to the portion of the bracket remaining with the platform. Clamp the platform back in position, drill through the extension pieces and the vertical angle on the transom and bolt them together.
Actually, the easiest thing would be to park it at my place, and, oh yeah, leave the keys!
Caretaker of the wife's '78 Ski Nautique
seejge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote seejge Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2004 at 6:19pm
Just sold a 76 Ski Tique and bought a 78 Ski Nautique. The 78 with deluxe trailer will not fit in garage without modifications (lengthwise). Anyone have any thoughs on a quick release kit or otherwise for temporarily raising the platform for storage? Thanks in advance.
La Banana de Jaybird
