  New Posts New Posts RSS Feed - the day after st.pattys day
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: the day after st.pattys day
    Posted: March-21-2007 at 3:46pm
im waiting on you randy!
Randy_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 1:06pm
If not Saturday, perhaps I could drop in on you Friday. You could bring that infected PC and maybe let me borrow your puller. Then I could bring everything back to you on Monday. I want to get this prop in before they start getting busy. I am going to need it back before it starts to get nice out We could always look at the strut bearing later.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 11:54am
so far looking good, pretty steady workload 50/50 at the momont
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 10:46am
Eric, What is this Saturday looking like for you? Supposed to be warm with a 50% chance of showers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 10:27am
From Hydromotive's website:
"Both lab finishing and blueprinting refer to the process used to insure the accuracy of the propeller rake angle, pitch, progression, pitch variation and cup. This hand process involves thinning the blades and sharpening the leading edges.
The advantage of blueprinting is that it reduces the horsepower required to turn the propeller and generates more usable horsepower for thrust. On an accurate, well-built propeller the speed gain may be 2-3 miles per hour. On a lesser quality propeller, the increase may be 3-4 miles per hour.
The disadvantages of this same thinning and sharpening are greatly reduced blade strength, fatigue resistance, and being more subjective to stress risers occurring at the sharpened leading edge. A sharp leading edge is very prone to minute nicks which create stress risers. These stress risers often propagate cracks that originate from the nick at the leading edge and work their way through the blade. The same thing is true for any nicks at the trailing edge. It is for this reason that we at Hydromotive grind our trailing edges from hub to tip rather than across the blade, thus eliminating any potential stress risers. Reducing the blade thickness from a 1/4" to a 1/8" (1/2 the original thickness) does not reduce the strength by 50%, but actually reduces the blade strength to 12% of the original. Consequently, we can not warrant any propeller that has been lab finished or blueprinted."
Hydromotive
This sounds like it would be good if you really wanted to tweek your props performance. I don't know about reducing the thickness of my prop by 50%. I think I would rather keep it as strong as possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 8:31am
I looked at hydros ws, and it says he blueprints props, first i heard of this but it may be worth a try...
says you can pickup 2 to 3 miles per hour?
fact or fiction?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-21-2007 at 8:23am
Did you guys try calling hydromotive? im just curious, I know you have coupons for santee's
Its just that he is about 2 miles from my house and i want to try him out this summer, I'll post in the future and stop by his shop, I think he has prop scan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2007 at 9:45am
Sounds good Ryan,
I picked up a pump you put on the end of a drill for pumping the tranny fluid. got it at Sears for $8. works great!
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 8:06pm
all good, considering i work in downtown...im gonna be taking my tariler to eric very soon so he can repack the bearings and check everything out..almost forgot the tranny fluid too..id do it but too cheap to buy a pump...plus hes the trans expert..id screw something up! well figure something out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 7:21pm
Ryan,
That would be great if you could take mine with you No problem paying you upfront. I have a 15% off coupon I printed off their website. I don't have a prop puller and the damn things are $70. Eric said he would pop it off for me. I could meet you at Eric's place and you could take it from there. Then I could drive out your way and pick it up or whatever. Save me on the shipping.
todicus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 6:42pm
I learned over the years that it is much more gratifying to regret the things you did while drinking than to regret drinking too much, along with it is much better to regret the things you have done, than the things you have not.
Living outside the wake
95GT-40SNOB
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 6:36pm
thats right, if your not puking you aint trying hard enough...and when racin to the bottom of a wine bottle..."if you aint first your last"
05 210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 05 210 Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 5:58pm
Originally posted by todicus todicus wrote:
Game on !! Fire up the hot tub and watch the ladies strip naked !!..
   Amen.I don't have a hot tub for the muscle therapy.
    And as far as I'm concerned,If you don't feel bad the next morning you simply did not drink enough
     Mike
Air Nautique 210 Team
640 hours, not 1 regret
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 4:24pm
give me your prop if ya want, sometime in the near future im going to drop mine off at sante marine..i have a 4 blade acme 422 that i beat up last year...save you money on gas or shipping. if thats who you were planning on having fix it..i got a 15% off card fro mthe boat show also i can give ya...only thing is your gonna have to give me the money when you give me your prop cause they want paid upfront
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 3:50pm
Next year graphics and decals and maybe make the trailer look nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 3:47pm
I have a couple gelcoat repairs to make but I need to wait for some decent weather. then I need to put the top pinstrip back on and give it a good wax job. reinstall the drivers seat. fix the zerk fitting on the trailer wheel. going to install a couple 12volt outlets on the kick panel and mount my XM receiver down there. Tighten the front lift hook (if I can figure put how to get to it in my sport...) and Eric said he would help me pull off my prop and take a look at my strut bearing. I want to send the prop in to get it reconditioned, I have a couple dings on it. Not sure about the strut bearing, so I want to have Eric look at it. then I should be good to go
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 2:36pm
randy whats going on with the boat now, since your done wet sanding?
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 2:35pm
my wish list..lol i wont even begin...lets says to convert it to a reality im gonna have to get some deeper pockets
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 2:29pm
I like that top too. I'll have to add that to my wish list. really like the strips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 1:49pm
Thanks Ryan........ I bought the boat used, and it came with the bimini with the zippered slit for the pylon. Don't know what it would cost, but I understand the multi colored bimini's are a little more that solid.
95GT-40SNOB
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 1:44pm
todicus- nice boat never looked at it before...where and what did the bim cost ya?..i like the cutout for the extended p
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 1:43pm
i think my problem was at around 11;30 we were slammin bottles of wine...dont ask me why..should stuck to the beer and shots
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 1:32pm
I was pleasantly suprised to discover that you can drink vast quantities of really good vodka like Kettle One and Grey Goose, and not wake up with a splitting headache.
95GT-40SNOB
PLBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PLBC Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 1:09pm
sure ya do
99
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 11:34am
i have got many many many..some a little too much to explain on here....
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 9:34am
thats one ugly puss, too bad this is a pg site, we need a topic for drinkin stories
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 8:54am
Meow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2007 at 8:04am
you aint lyin 79, they shouldve stayed home with the girls, Ive been on the edge of death from alcohol and still made it in the next day, thats the price you pay
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2007 at 9:31pm
kids these days just cant' hang with the big dog's otherwise you would have got up had a bloody and a few more cold pops and been fine, works everytime.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 05 210 Quote  Post ReplyReply Direct Link To This Post Posted: March-18-2007 at 7:19pm
   I feel your pain.
     Mike
