no spark when crank but spark when off 2 |
logicsound
Groupie Joined: July-24-2006 Location: United States Status: Offline Points: 46 |
Posted: April-03-2007 at 12:38pm |
THANKS ALOT !!! Will look at the boat tommorrow.
Once again thanks alot, this is exactly what I needed. Trev |
Take a look at this, it may help:
It should be noted that the connection between the green, purple and red wires (for the alt exciter, ign feed and choke, respectively) are not tied together physically at the ballast resistor. I believe the connections are made internal to the wiring harness. Same goes for the grounds. |
logicsound
well in 79nautiques post he stated that my wiring is wrong. that I should not have a red wire coming from my breaker going to the ballast, and that I should have a purple wire connected to both sides of ballast. I explained what my wiring is in my previous post but did not get a response on how to fix it.
So my question is how should it be wired. were does the purple wire come from and where should the red wire from the breaker go ? Thanks |
Which question are you referring to? |
logicsound
can anybody answer my above question ? there has gotta be someone that knows this ? looked at wiring diagram but does not tell me.
Thanks |
logicsound
79nautique, I somehow missed your above post in here.. my wiring is as follows. from the block where the postive cable from battery goes I have a red wire that goes to the 40 amp breaker on the other side of the greaker I have 2 red wires one I don't know where it goes (i think wiring harness, I have to look again) the other one use to go to one side of ballast and then a purple wire from the other side of ballast giong to + of coil. (these are connected together now) If this is wrong can you tell me where that red wire from the 40amp should go and where the purple wire Im missing should come from?
Thanks Trev |
eric lavine
try removing the gray and try it, only takes a couple seconds
wannabeSS
Senior Member Joined: March-01-2006 Location: United States Status: Offline Points: 125 |
http://www.centuryperformance.com/mallory/unitest.asp
96 Camaro SS #1157
84 Ski Nautique, fat sacks, fly high pole 06 LF Fish 125 06 LF PS3 137 |
Thats the wire for the tach. |
logicsound
i have the electronic conversion. so no points. getting frustrated. this should not be this complicated. what is the grey wire on the - side of the coil for? that is the only thing I dont know about.
eric lavine
I spent 3 days messing with points and coils, it was 2 situations for weak spark and intermiitant running. on one the tach was shorting the coil and the other the NEW condensor was bad. on both i wouldve never thought possible...just something to look for
79nautique
there should have been two purple wires going to the ballast resistor one on each end if not then someone have screwed with the wiring and has it wrong. The feed from the breaker should not go directly to the ballast resistor |
logicsound
thanks jeff. I have the electronic igition conversion and there are only two wires a red one that goes to the + on the coil and a black one that goes to the - on the coil. I also have the a purple wire coming from the ballast (which I bypassed, red from 40 circuit breaker and purple connectted together)going to the + of the coil and a grey wire on the - of the coil.
(coil has internal resistor) |
JEFF KOSTIS
Again, you are getting a constant ground to the NEG terminal on the coil. Either a case like this usually means points or a module thats shorted. Make sure there is no shorts in the wire or insulator thats in the distributor.
Jeff... |
logicsound
ok so I read the post about no spark when cranking but spark when turned off and my situation similar but a little different. I have a 86 martinique. I have a new coil, new wires and brand new electronic conversion, and I have 12 volts at the coil. and my rotor turns. Just to clarify I have no spark when cranking but spark when the key turns off Please Help! The boat stop running last year, and I was hoping it was just the points. I installed the new coil, wires, elec. conversion and it still did not fire. It sounded like it wanted too and then it backfired, and nothing since.
