  New Posts New Posts RSS Feed - rudder removal
rudder removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Topic: rudder removal
    Posted: August-12-2021 at 6:46pm
John
Something tells me you probably meant to post this in the thread you started recently in the link below and not onto this thread that had been inactive for 14 years .....till now Wink
john_sn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john_sn Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2021 at 6:37pm
Removing the old parts went smoothly. I removed the rudder, then slid out driveshaft. The coupler came off with some PB Blaster and some taps with a rubber mallet.
The prop on this boat was a Michigan Wheel 13x13 RH. The folks at general propeller thought that was strange.
Here's some pictures:
gun-driver, im with wayoutthere, I don't think I can use a dripless seal because I don't have the plumbing for it. I put a float switch into the bilge so it auto pumps and the leaking water isn't a concern.
New parts are on their way, and I'll post again when I start putting it back together.
Here's the best photo I can offer for tribute... It will look a lot better when we can get back out on the water
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2007 at 2:44pm
Hate to see you spend the money renting a hoist for such a short period of time, but I'm glad it worked out for you. Have we seen pictures of your boat yet? BKH
Livin' the Dream
acedizzle916 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acedizzle916 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2007 at 2:29pm
thx bkhallpass. i went down to a shop and rented an engine hoist for about 25 bucks. got it all taken care of! thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: April-13-2007 at 6:03am
Double check the prop guard to see if it can be unbolted. I know that mine can. Two large bolts and that puppy is free!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 10:24pm
If you've got an engine hoist, you can lift the back of the boat up from the lifting ring. You can use a floor jack and a block of wood - I place the jack under the transom to the sternside of the rudder. You only have to lift it a couple of inches. BKH
Livin' the Dream
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 10:24pm
I'll answer for David,
You can use Life Boat or is it "Boat Life" sealent, I'm not sure what the name is, but I have used it. Good stuff that will keep water out and yet still come off later.
The rudder shaft does not need grease. And, you can tighten the stuffing box on the rudder till it doesn't drip.
Chuck
Walk on Water
www.coldwater.me
69 Ski Nautique
Clew In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clew In Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 10:10pm
When putting the rudder back together should you grease the shaft and how tight do you tighted the screws above the stuffing box?
Clew In
Clew In
Post Options Post Options   Thanks (0) Thanks(0)   Quote acedizzle916 Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 7:19pm
Hey David, you were right about the rudder not having enough space to drop down because of the prop guard on teh trailer, so how do i jack the boat off of the trailer properly? Are there specific lift points? I'm afraid of damaging the bottom of the boat.
88 Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 Nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 6:03pm
Would you NOT use 3M 5200 to replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote acedizzle916 Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 5:58pm
your a life saver. thx a lot! :)
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 3:39pm
1. Get a six pack of beer and start drinking. What else matters?
2. Remove rear seat.
3. Remove rear panel.
4. Remove rear floor board (might require removal of doghouse.
5. Remove saftey wire at top of rudder post/tiller arm.
5a. Support rudder from below (do not let it drop).
6. Remove bolt from top of rudder post.
7. Loosen clamping bolt on tiller arm.
8. Lift tiller arm up off of rudder post.
9. Remove rudder from below. may require jacking boat off of trailer bunks so rudder clears prop gaurd, if so equiped.
If replacing/removing rudder port, simply remove nuts from bilge side (4 ea.) and work rudder out from below...it will be stuck with sealant. If PO used 3M 5200, you can cuss him now and go get the twelve pack....you will need it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acedizzle916 Quote  Post ReplyReply Direct Link To This Post Posted: April-12-2007 at 1:35pm
can anyone talk me through how to remove the rudder assembly from my 83 ski nautique?
