  New Posts New Posts RSS Feed - Lake Scum Remover?
Lake Scum Remover?
Randy_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Lake Scum Remover?
    Posted: May-09-2007 at 11:27am
My trailer is trashed, and I know it was from the PO using muriatic acid to clean the boat. If i ever get a new trailer Muriatic acid will never come near it. I am with behindpropeller on this one.
If you do use the acid, at least wash off the trailer REAL GOOD. In my case their is carpet and wood that hold the acid water to the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2007 at 4:31pm
Yes.
Actually my trailer looked good before I tore it down. Underneath the bunks is where is was corroded. Lots of 1/8"+ pitting.
Tim
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2007 at 4:19pm
Behindprop,
Have you ever used The Works? I've used it on my pontoon for 9 years (painted trailer) and my outboard for 8 years (also a painted steel trailer). Both trailers show no ill affects from the product, though the pontoon trailer I share with some buddies who trash it.. My outboard trailer still looks brand new. Now muratic acid, I have not used it on a boat while on the trailer.
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2007 at 2:58pm
I guess tufffooter and RA don't care about their trailers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: May-08-2007 at 7:12am
I've had great results with a toilet bowl cleaner called "The Works". I pull the boat out of the water, spray it on, let it set for a minute or two, and hose it off. Sometimes I use a car brush if the scum is stubborn.
Good luck.
'85 BFN
'90 BFN
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2007 at 8:56pm
muratic acid is the sh*t..if nervous about it use my trusty trick..take your 2 gallon weed sprayer and dump a large bottle of hydrogen peroxide and one bottle of lysol toliet bowl cleaner(blue) into it...then fill the rest with water...spray it on and watch for 1-3 minutes and wipe off..try it
BlondieGurl1443 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BlondieGurl1443 Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2007 at 6:48pm
I havent found anything that works as well as this without the harshness!
starbright
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2007 at 6:41pm
soak the boat or the brush in the lake first??? Just kidding I know you ment to soak the brush in the lake first. I am having way to much fun at work today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2007 at 10:56am
I agree with behindpropeller. That acid is bad stuff. My trailer is really rusted out from the PO using acid based cleaners. I used the acid when I first got the boat. Bad stuff, had my lungs burning, skin burning. I don't ever want to use the stuff again! I had good results with Purple Power cleaner I got at Advanced Auto and a good stiff brush.
soak it in the lake first.
after you get it clean apply a coat of wax to keep it easy to clean
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2007 at 10:22am
They all contain a acid of some type at different strengths. Rinsing with lots of water is important.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2007 at 9:33am
I would not use acid.
I just repainted my trailer for my '86. I used to clean it with acid for about 4 summers before I had a lift. The steel is all pitted from the acid. If I had not done the trailer when I did I would not have a trailer anymore!
I used to use toilet bowl cleaner, you get it at the custodial supply store.
Tim
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 8:06pm
use a product called Slimey Grimey, if i didnt see it myself i wouldnt of believed it, spray it on and the algae build up drips right off..... it probably has muratic acid in it
dborrelli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dborrelli Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 5:15pm
OK Thanks I'll try it. I have had some experience with muriatic acid before (fun stuff).   But if it works then it will save me a lot of time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 4:58pm
Originally posted by M3Fan M3Fan wrote:
Interestingly it does turn the nibral parts green when it hits them, which is probably why I see a lot of boat ads where the running gear looks like it has green corrosion on it- they clearly used the muriatic acid on the boat! Don't worry though- the green corrosion is not permanent on the running gear.
Same thing with the On/Off. Muriatic acid could very well be the active ingredient.
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 4:55pm
Muriatic acid works great. I didn't discover it until this year, and I was a bit nervous spraying it on the hull of my pride and joy but sure enough it is harmless to the hull and stickers and just eats out the bad stuff. I cut it 50/50 with water into a commercial spray bottle. Do not breathe in the vapor or do it on a windy day, and do hose down the boat and trailer right after.
2016 SN 200 OB 5.3L DI
https://forum.fifteenoff.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 3:40pm
On/Off works great- its very strong stuff. Just dont let it sit long on any painted surface (trailer, etc) or decals. Ive also heard muriatic acid works well.
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 3:22pm
I've heard people like the on/ off or on and off...whatever it's called.
You spray it on, then hose it off.
Personally, I use a good cleaner wax and lots of elbow grease. Wax has an abrasive element to it, so a good quality cleaner wax should take off the lake scum.
Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dborrelli Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2007 at 3:06pm
I was wondering if anyone knew of a good way/product to rid my boat of "lake scum" that has built up over many years. To me it seems like the only way to remove it is to sand it off but this way is extremely tiresome and time consuming not to mention bad for the gelcoat.   Any suggestions?
