Temperature Guage |
69 Mustang
Senior Member Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
Posted: April-27-2007 at 10:00pm |
I had the same question/problem in my 78 SkiTique...it was the t-stat, or rather, lack of one. It came out in 3 or 4 pieces. Popped in a new 143 degree unit from skidim and it works like a charm. Oh, this was after installing a new sender (no change) that I later removed and replaced with the old one.
Kept the new sender as a spare. |
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
87BFN owner
Grand Poobah Joined: August-25-2006 Location: Saline, MI Status: Offline Points: 2194 |
The manifolds even under regular temps will be very hot to the touch, question is whether they are to hot. Did you check to see how much water you were flowing out the exhaust. I check exhaust water flow first thing every time out. You don't want to warp the heads or burn your exhaust hose up.
zigman
Newbie Joined: April-25-2007 Status: Offline Points: 5 |
nuttyskier...thanks for the info. I will try testing it as you described.
Tomski....the boat was in the water and the gauge still doesn't work. Thanks for the ideas though. |
Tomski
Senior Member Joined: October-19-2006 Location: United Kingdom Status: Offline Points: 227 |
Have you had it out on the water?
I've just been through this with the boat on the drive. In the end it turned out there was no stat fitted and with the constant feed of cold water from the hose and no load on the engine it just didn't get warm enough to move the needle. After a new sender and lots of circuit testing a $10 part fixed it. At least I've got a spare sender now. |
Easily Parted From Money
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
The temp guage has three terminals on it's backside. These are I (or ignition), Gnd (ground) and S (Sender unit). With the key on, make sure you have battery voltage accross the "I" and "Gnd" terminals. If you do, next check the send terminal for a good connection to the temp sending unit. To verify that the guage is working, disconnect the wire at the sending unit and connect this wire to a 100 Ohm resistor (you can buy one at Radio Shack or Fryes Electronics). Attach the other end of the resistor to ground. The guage should read approx. midscale. If this is all good - replace the sender. You can get one from NAPA or the manufacturer of the guage.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
zigman
Hello,
I just purchased a 1978 Ski Nautique and noticed that the temp. guage is not working. I wasn't sure on how to diagnose the problem, so I thought I would start by replacing the sending unit. However, I am having a very difficult time locating a new part. So, my questions are: 1) Is it most likely the sending unit....or is there an easy way to test. 2) Is there a way to cross reference the sending unit to something that I may find at an auto parts store? 3) Any other suggestions as to where I could locate a new one? I am paranoid that I am overheating the engine. I can feel water going through the manifolds, but they sure get hot to the touch! This is my first in-board so you will have to excuse my ignorance. Thanks for any information. |
