  New Posts New Posts RSS Feed - starter problems
starter problems
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Topic: starter problems
    Posted: April-30-2007 at 5:46pm
Just dissable the coil so it can't start. Once it is cranking ok take it to the lake. Don't hook from the trailer until your sure it's running right.
That's why I love working the afternoon shift. I goto the lake back the trailer in the water let the boat run for a while, then take off. I never even pull the truck out of the launch. No one there to bother it.
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2007 at 6:54pm
For the problem you are facing (engine not turning over) you don't really need a supply of water for just cranking the engine over. Just don't let it run for any longer than about 10 seconds - else you will burn the raw water pump up. Any longer than that and you will at least need a water hose.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
bcwhitaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcwhitaker Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2007 at 3:08pm
I do have a voltmeter, and the batteries are fairly new. The guy I bought the boat from suggested that it might be a loose ignition wire. I plan to check the voltage on the batteries and check the ignition wire itself. Besides trying to start the boat on the lake do you know of any other place to try and start the motor. I live in an apartment complex and do not have use to a water hose.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2007 at 2:15am
battery
wakeboardin2k4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2007 at 2:12am
might be time for a starter rebuild. I was having similar issues. I got a new optima blue top battery and had my starter rebuilt. Boat starts first time every time
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2007 at 12:23am
What is the condition of your battery? Do you have a voltmeter (multimeter)?
Former boats:
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcwhitaker Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2007 at 8:09pm
I just bought a boat with a ford pcm 351 and have taken it out to the lake twice. It had problems starting up before where I had to pump the throttle a few times before it would turn over. Mainly this was only on cold start but then it would take a while to start after being ran for a while. Today I took it out and it gave me problems starting it but it finally started. Then while waiting on some friends to park the truck and trailer it died. When I tried to restart it, the starter seems to be getting juice and it just whines and never turns over the engine. Does anyone know what this might be?
