  New Posts New Posts RSS Feed - Rudder loose
Rudder loose
74 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 74 Skier Quote  Post ReplyReply Direct Link To This Post Topic: Rudder loose
    Posted: May-17-2007 at 2:51am
My rudder has the same play, I think it's from all the "whirlybirds" I've done!!!
Shake and Bake
1974 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2007 at 9:56am
Swifty, I don't know the tolerances of the rudder shaft to the port but do know they aren't real close brand new. My 54,64 and 77 all have the side play. Tighten up the packing or replace it and run the boat to see what happens. Unlike the prop shaft packing, that is always rotating, the rudder packing can be clamped down quite tight.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2007 at 9:52am
The rudder on my '77 Martinique was loose in the port as you describe and I experienced no ill effects such as harmonics/vibration.
I believe the force of the prop wash was enough to hold the rudder hard against the port in any given place. I suppose you could get some adverse effects if the steering was absolutely neutral, which mine was not as I do not like neutral steering.
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2007 at 9:33am
It sounds like the shaft is worn. I'm not sure about the Tique, but on my boat I simply remove the rear seat to gain access to the rudder. If you want to take it out to check it, loosen the nut on the control arm on top of the rudder. Have someone under the boat, or I have used a proped up milk crate to catch the rudder when it falls. Maybe if you take it out you can see if the shaft is worn, or the rudder port. If it is the port these guys sell them: Buck Algonquin
Chuck
Walk on Water
www.coldwater.me
69 Ski Nautique
swifty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swifty Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2007 at 9:16am
It is a 76 Ski Tique. If you grab the rudder you can wigle it in backeards and forwards and side to side under the boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2007 at 10:35pm
Swifty,
What year and model do you have? Is the rudder loose in the port? Or, is the port loose?
Chuck
Walk on Water
www.coldwater.me
69 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2007 at 7:23pm
Andy, Have you tried tightening the packing nut? How loose is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote swifty Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2007 at 6:07pm
Is there anyway to tighten the rudder? Will this cause alot of harmonics also?
Thanks for the Help!
