Cracks in Gel Coat |
David F
Posted: June-12-2007 at 8:38am |
Probably just one of those things. Gelcoat far more brittle than the modified epoxy resins that CC uses. Probably, the cold temps caused the problem and the cracks originated from a screw hole under the rub rail. Gel cracks are a part of life and every boat will suffer from them eventually.
04, If you are lucky that the cracks are only in the dark color gel and don't go farther (structural like skibum mentioned) you can grind them out and try color matching in new gel. You will however never match the color exactly and you have said you are a meticulous person.
I doubt that the heat gun from the shrink wrapping had anything to do with the cracking. A dark color will heat up more in the sun than the brief time the heat gun is used. |
04Avant
Newbie Joined: May-31-2007 Location: NNJ, ADKS, NY Status: Offline Points: 4 |
Looking at the cracks. They appear only in the stripe colors (green and tan). They don't extend beyond the stripes and into the hull color.
I wonder if when the boat was wrapped, they overheated the area when they were heating the plastic. As far as trailering too much, I tow it from Jersey to the Adirondacks in the beginning of the summer and trailer it home after Labor Day, about 600 miles each year.I leave it on the trailer at the marina during the week and put it in the water for the weekend. I don't think I'm trailering it too much. What's the fix for cracks in the gel coat? Lousy way to start the season. |
SkiBum
Stress cracks and spider cracks are a common problem. With a 97 they can be related to structural issues like stringers and the floor. Could be from trailering or a number of things. Problemis the cracks in the gel are what you see on the outside when there are cracks in the glass inside.
04Avant
These cracks weren't caused by anything hitting the boat. Boat was fine when it was wrapped and put away for the winter last October.
eric lavine
yeah, I have a boat here with cracks on the port side all the way through, except i know what caused it, a waverunner hit the side and there is still some hair in the cracks, did he survive.... I dont know, its cracked through into the inside
Eric |
04Avant
Just unwrapped my 1997 Ski Nautique and as I was washing it I noticed 5 vertical cracks in the gel coat on the right side of the stern below the rub rail. The boat was perfect before I had it wrapped for the winter. My Nautique has less than 200 hours on it, is meticulously maintained and is usually kept on the trailer.
Anyone else have or have seen this problem? |
