  New Posts New Posts RSS Feed - trans question for Eric
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: trans question for Eric
    Posted: June-04-2007 at 7:34am
I pump it out with a vacuum type pump, on larger boats i remove the cooler line and fire the engine and let the trans pump it out. i would get 3 qaurts and start with one and a half and go from there. when you know its to the right level, the next morning you can make a cold level mark so each time you fire the boat you can check the level when cold
josh84/2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josh84/2001 Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2007 at 7:59pm
Eric what is the best way to change the tranny fluid and how much do I use. I have a 83/2001sn with a 351 Lh rotation don't think the color matters. think its time to give her fresh fluids
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2007 at 7:56pm
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2007 at 11:52am
amsoil? or one of those off brands i think
bmiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmiller Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2007 at 8:21am
I screwed up it is dexron mercon that I put in my tranny.So Eric what tranny fluid was in the on that you took apart that turned purple on you?Just curious
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2007 at 7:37am
Dexron Mercon,
I pulled one apart yesterday and it had a purplish fluid in it, all the o-rings were twice the size from swelling
Post Options Post Options   Thanks (0) Thanks(0)   Quote bmiller Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2007 at 2:34pm
Gary,I just use dexron in my 78 mustang and it seems to perform well,so should be ok.I'm hoping that Eric will concur.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2007 at 1:47pm
Hi Eric- Just getting my boat ready for Green Lake.Sorry to have missed you on the phone,just want to conferm fluid change.Dextron 3 and flush cooler hose's? As far as I know original Borg Warner,working fine,changed fluid regularly since I bought in '89.I haven't used boat in 3 years can't remember what oil I used then. Thanks Gary
