2000 GT-40 wont restart once warm |
Tiquer
Newbie Joined: August-08-2004 Location: United States Status: Offline Points: 1 |
Posted: August-08-2004 at 8:28pm |
I was told that lifting the hood relieves vapor lock. Obviously that is an uncool way to fix it, but if it is vapor lock perhaps a higher output blower motor might help or better hood ventilation.
Rj
nms1991
Groupie Joined: May-31-2004 Location: United States Status: Offline Points: 46 |
You need to see if you have no fire or no fuel when you try to start the engine. no there is no ballast resistor nor is there a switch to keep the motor from starting if it is to warm.
David F
I know very little to nothing about the newer boats, but this is a strange problem. What could opening the doghouse possibly have to do with the engine starting or not. Does your boat have a fume detector that locks out the ignition? Opening the doghouse releases teh fumes. I know, a long shot but noone else is offering to help.
Does you boat have a ballast resistor, I would think not... Does it start immediately upon opening the dog house or are you just helping something to cool down like the engine. Does you boat have a over temp sensor that keeps it from starting? Good luck. |
Chip
Guest |
2000 with the GT-40 won't restart once warm. If I open the dog house it starts fine. Some kind of temp issue. anyone else experience a fix for this.
