Tires |
David F
Posted: June-08-2007 at 11:05am |
Carlisle tires are absolute junk. You are better off going with Goodyear Marathons or Greenball/Tow Master II. Do a bit of research on the web and decide for yourself.
I do not have a CC trailer, but I used Greenball, F78-14/C1's on my tandem axle trailer. |
79nautique
245's are way to large
215-225 14" is about right, just check the rim width if they are to wide then the 215-225's wont fit right either need about a 6-7" wide rim. |
Towman
Groupie Joined: June-22-2006 Location: United States Status: Offline Points: 76 |
Thanks guys 79 PO put 245 on and they look way to large
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
I just bought a set about a month ago. Most likely you need a 215 14". Carlisle is a very popular brand of trailer tire. That's what alot of U-haul trailers use. Car tires are for cars and light trucks and are NOT designed to handle the heavy loads of a trailer. They also behave quite differently as they are subjected to different circumstances.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
79nautique
by trailer tires in the same size that are on it now.
Towman
What is the correct size trailer tires for a single axle built in 1985.P O of course went and changed with larger car size.
