302 Ford cooling problem |
64 Skier
Posted: August-16-2004 at 4:41am |
You also have an orifice on the downstream side of the manifold. the brass fittings that screw into the manifolds inlet and outlet, if swapped might affect what you're describing.
I mistakenly swapped mine during a rebuild and turned some shiny new paint "brown". |
marks
Groupie Joined: April-23-2004 Location: United States Status: Offline Points: 96 |
I don't have any first hand experience on this, but I thought I would throw it out for the experts to comment on.
Could the riser gasket be installed backwards? I seem to recall reading that on the Ford engines, the riser gasket is designed to block the rear water passage, forcing the water through the front one. |
nautiques1
Newbie Joined: December-10-2003 Location: Canada Status: Offline Points: 23 |
The manifold was real hot and boat has not been in the water for 3 years so I will put the shaft back in and try it in the water. Thanks guys.
Gavin Grant
Desbarats Ontario Canada |
nms1991
Groupie Joined: May-31-2004 Location: United States Status: Offline Points: 46 |
try the boat in the water some times they need back pressure from the lake to operate properly.
yellowdog
Senior Member Joined: December-21-2003 Location: United States Status: Offline Points: 135 |
The thermostat is easy; skidim.com, there's a link on this site for 10% off. I am sure you will find something else to buy! BUT, if it is only getting to 160, the 'stat must be opening.
Was the manifold too hot to touch or just really warm? Front or back? Were you getting enough water from the hose to properly cool the engine? The 351 in the '78 never gets above 140 on a hose. Could be there's a blockage in there but with the equal flow from each side, it does not sound right. |
Caretaker of the wife's '78 Ski Nautique
nautiques1
The 1969 ski Nautique I am working has a 1968 302 Interceptor 210hp. I just got it running last week and I noticed the left side manifold was very hot compared to right. It was hooked to a garden hose and there was equal amounts of water coming from each exhaust and the water was still cool. The temp gauge went to 160 and I think it should be 140. Where should I start looking for a blockage and where can I get a new themostat. Thanks Gavin.
Gavin Grant
