What do my plugs say? |
Post Reply | Page 123> |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Posted: July-06-2007 at 6:46am |
Jared, I'd be glad to go with you to Saquaro in the early morn. I go sometimes on Mondays and Tuesdays. I got your email with your phone number. This weekend I'm going to Rocky Point with my girlfriend and her family. We will be there thru next Tuesday. So we will have to make it the weekend after. When was the last time you had your boat out and how did it run? Anyway, I'll give you a call next week (probably Tues) and we'll go from there. Take care! Brian.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
sjpitts
Senior Member Joined: April-16-2007 Location: United States Status: Offline Points: 111 |
This is the same boat. To clarify, they did two compression tests. The first gave a reading of 20lbs in one cylinder, but they said it could be rust on a cylinder wall, so they said they would first run it for a while and then do another compression test. They did, and said the compression "came up" so it probably was rust. They never told me what the final compression was, or how much it came up. They just said that there was a decent chance the motor would last a while. And it has lasted 15 months with 50 hours of use since then. Rust on the cylinder wall actually makes some sense, as the guys on this forum pointed out that the manifold/riser gasket on that side was stained from leaking, and then I saw actual water coming out of that same gasket. I am Mesa, brown road/gilbert road area. I would love some help sometime. As I said, my next task to learn how to do my own compression test, checking to see what my compression is now, and if it is a valve or ring problem. I could also use some help figuring out why it is running rich. How do you feel about early morning lake trips? We usually leave for Sag at 4:30 AM, and are home by 8:30 AM. We go on some saturdays, but prefer weekdays. Jared |
nuttyskier2002
Are we talking about the same boat here? In one of your earlier posts you said that one of the cylinders was down to 20 PSI on the compression. That's a serious mechanical issue with the engine. Are you saying that the same mechanic that knows this also told you that the "engine itself should be fine". If this is true, this person CANNOT be trusted. Take it to another mechanic for another compression test if you don't know how to do one. Didn't you say that you live in the Phoenix area? I'm in Tempe and the offer still stands if you would like help with this thing. Brian |
sjpitts
Just to be clear here--the boat shop said the compression was low, and that it was running rich, but they also said the engine itself should be fine. The mechanic told me it could last a long time. They didn't try and sell me a rebuild, a valve job, or anything else of the sort. I am going to the lake in the morning. I may try and do a new, complete compression test afterwards Jared /hoping the boat shop was right. |
79nautique
be there when they do the test or spend 20 bucks and get your own tester at the local autoparts store. And after the compression test is finished do a leak down test on the bad cyclinder and listen at the carb and see if you hear air coming out of it or listen if air is coming out of the oil breather if so them you need the valves done if it is in the block and you hear air coming from the didstick tube then it's the rings.
Watch out!! There are shops out there that may not be truthfull. They would rather sell you a total rebuild when it only needs a valve job. Worse yet is a re power! Definately get someone else to do a compression test even if you do get a answer for the first shop. |
64 Skier
Sorry, my brain stalled...those plugs should have been light brown to chocolate in color so you not only have an internal issue wiht the compression, but a fuel issue as well. I suggest some major work or your gonna find yourself in the middle of the lake needing a tow.
I know it's bad news, but it's not something that can't be fixed. A tank of gas costs almost as much reworking a head and as the old saying goes "if you can't afford the gas you can't afford the boat". Give that engine some TLC and it'll so much fun you'll never look back. |
64 Skier
The boat shop ran compresion twice and gave you bad news (low compression) twice....but did not tell you "WHY" you had low compression. Need a better/smarter mechanic. Tell a better one a little history and specifically ask him if it's the valves or piston rings or possibly something more serious like a crack.
I agree with what 79 said that until you know the "WHY" you don't know what to do. The boat shop should have been able to tell you that on the second test so IMO, you need to change shops. Either way get the work done ASAP. If it's just a valve, then the repair is cheap and easy. If it's the rings/bore etc and your risking the crank or block, then again, you need to repair ASAP. |
gigem75
Senior Member Joined: November-12-2005 Location: United States Status: Offline Points: 239 |
someone mentioned this before but when you run your next compression test, squirt a couple of teaspoons in each cylinder right before you test it. If the compression comes up significantly your problem is most likely the rings or cylinder issues. If it stays about the same that indicates valve problems. If that is the case you could do a quick changeout of the heads and be back on the water in a weekend.
Running rich can be as simple as a stuck choke or the float level being set to high. |
sjpitts
All right, so everyone agrees I have a serious problem.
A few people think I can try and wait it till winter, but most of you think that is asking for a blown block. I would really rather wait, but guys are making me nervous. I think I will try and do a new compression test on Saturday--at least one the weak side-- and try and find out what those numbers really are, and try and find out if its is rings or valves. And how can I find out what is making it run so rich? What would you check first? Jared |
79nautique
well you could run it until winter but if you throw a rod, or trash the crank then you have nothing to rebuild and have to replace. Throwing rod means cracked block, maybe even a hole in it, which means junk, scrap steel, no core exchange for that block.
you really need to know whats bad in the #5 cyl is it a bad valve or is it a bad piston/rings. If it's in the top end then a valve job is all that's needed and your up and running like new. |
Riley
I hear them NGK plugs are good for overcoming a lot of engine problems. I put one in my old Briggs and Stratton, and now it runs like a Honda. Starts first pull every time.
gigem75
Actually the worst thing that could happen is putting hotter ngk plugs in it:)
If it's a reverse rotation engine the last thing you want to do is mess up the crank. When you do get it rebuilt you'll wish you'd done it sooner. |
Riley
You've got nothing to lose by running it. Run it like hell all summer and worry about it over the winter. Worst that can happen is that it blows up and you need a new engine, which is what your being told anyways.
eric lavine
its probably burning twice the fuel it would normally burn, the fuel in those low cylinders will start to wash the walls and you will start to scuff piston walls if not already at that point, this could possibly do many things such as sieze a piston and thrw a rod through the side of the block...well you get the point
nuttyskier2002
Jared, even on a dead cold engine 20 psi on any cylinder is way below specs. And you have quite a bit of imbalance between the left and right bank. I'm sorry to say buddy, but you need to start shopping for a long block assembly (or at least a short block). Your engine is tired. And running it in this condition is only going to make it worse. Listen to 79 and the boat dr. When you replace or rebuild that engine you'll be very happy with the way your fresh new motor performs as compared with the old.
sjpitts
This thread has taken on a life of its own. Let me try and get it back on topic.
To recap some history--in the spring of 06 I took the boat to a shop to have it checked out. This was about six months after I bought it--after it had been sitting in my driveway over the winter. I had them do a compression test. After doing the test, they said they had some bad news-- they said very low compression in one cylinder. BUT, they said that it might be rust on the walls, and they wanted to run the boat again and re-measure the compression. After doing so, they said the compression came back up-- but didn't say how much. This actually makes some sense, as I now know that the riser gaskets were leaking on that side. But the boat shop guys said the engine wasn't really in that bad of shape-- that even though the compression wasn't that good, that the engine could run for a long time. With the exception of a few hickups, the engine seems to run pretty good. As I have said before, I don't travel that fast-- the fastest I go is about 35 MPH at about 3k RPMs. The boat does that just fine, and I don't have the need to go any faster. So with all this, do you guys really think that my engine is about to die a horrible death? I know someone said that I might not make to the fall. Is it really that bad? I know-- you are probably going to say I need to do a new compression test. See what my numbers are now. Right? Attached below are pictures of the manifolds showing the compression numbers they got. The port side, with the low numbers, is the one that had the gasket leak. I edited the spark plug pictures to show which plug came from which cylinder by putting the compression numbers above them. The lowest was 20 when measured the first time, but I don't know what it came up to. So tell me what you think-- and be nice (if not to each other, at least to me:)) Jared |
eric lavine
Doc you might get rapped up in a Mal-practice suit after this one
79nautique
sure not looking too good right now had to empty my pockets last Friday and it's going to take a while to fill them back up and aford to go to GL |
boat dr
Chris,need to send him an invoice for 5 min. of rent time inside my head.Then I started to work my program again......
Hope you can come to G/Lake,we will need someone to keep the troops in line there,and Chris is nominated for the commander in charge.........Will personaly buy you a brewsky, won't drink one ,but damn shore buy you one............... boat dr |
79nautique
thought doc was going to come unglued their for a minute. Pretty strong words wasn't sure if it was a local guy or the Doc he was refering to.
eric lavine
gotta love this site, i didnt realize a cat fight was going on
79nautique
it's not a timing issue it's a cash flow issue and right now all my cash is flowing away from me. |
boat dr
gigem,first off thats all a lie;
#1 you don't have any friends #2 You have me confused with someone else #3 You don't have a clue about The Boat Doctor, or where my shop is. #4 If he has a C/C in my shop, there would be little or no labor charge #5 Be careful about whom you attack on a professional level #6 This has gone on too long,the site is for sharing our experiences,our contacts,and how we keep this old stuff running. #7 What to do, but mostly what NOT TO DO!!!! I run a clean reputable shop,and take pride in my knowledge of the marine industry as a whole. Do I know it all, hell no ,I am a stupid white boy just trying to get to Heaven. I reassert the statement "be careful about giving advice on this site" some of the newer members will take your typed word as law..................boat dr |
gigem75
A friend of mine just spent $1,100 at the boat dr. Ran like crap when he got it back which was the same as it was going in. The timing was set at tdc, the bolts holding the float bowls were finger tight. The rear float bowl gasket was replaced but they didn't even scrap all the old one off! Not to mention just about every other bolt on top of the engine. The plugs were the same ones that were in there when he took it in. Choke was adjusted shut even when hot which was why the plugs were fouled. The accelerator pump was installed where the pump arm was backwards so that didn't work.
I fixed all this for him plus put new bearings/races and seal in one side of the trailer. I didn't charge him a dime, he's a buddy. It idles so smooth now with the NGK plugs (just kidding!) you can't even tell it's running. No wonder you guys (as a whole) not you specifically so don't get your panties in a wad, have the reputation you have. Right up there with the MB service departments. |
boat dr
Chris, you just about got him back in line,,,,
and as far as "vile" goes,please use simple words for the doctor. I prefer contemptable,paltry,despicable or sordid. You also stated that you used to "turn wrenches for a living" what do you do now,sales or just advice....... This is what The Boat Doctor does every day, I do boats and motors, not just talk about what I have done.This is what I DO,every day,Boats and Motors,some days Motors and Boats. This what I do and who I am,VILE, I don't think so,blunt yes...... You can reply with all the POS's, donkey's, and sucks all you want but if you need help I'll be the first to arrive and the last to leave and bring the beer. Talk is cheap and your advice about the same ............boat dr |
gigem75
the reason I brought up an old porsche is because I was accused of having a toyota and a honda lawnmower and my name isn't BUBBA. It wasn't the high and mighty I'm better than you attitude you thought I meant. If you knew me you'd know that. You might have given me a chance instead of twisting off like you did. When I twisted wrenches for a living we had a saying... toyotas are made out of a new japanese alloy, sh*timum. Perhaps if the first reply from the dr handn't been so vile and me being accused of owning rice burners all this probalby could have been avoided. Hell I kept my Norton long after I was being toasted by the honda 750's. Ok so now you'll probably slam me because I owned british crap with lucas electrics. whatever. The point is we all know that heat ranges and resistance varies from manufacturer to manufacturer, they don't coinside exactly and it is possible that since he has low compression on one side that there is a plug that might and I repeat might work a little better than what the factory calls for in this situation. If I would have said champion I wonder if we'd be having this discussion? Course that would never happen because I dislike champion plugs as much as you hate ngk plugs. I can pretty much say I wouldn't have trashed you if you would have said that just because I don't like champion.
And just for the record your pedigree sounds good to me. I also like my American muscle as much as anyone. So there you have it. You can reply with all the POS's, donkey's, and sucks all you want but if you need help I'll be the first to arrive and the last to leave and bring the beer. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
No, V=IR. For the record I ran NGK's in my Nissan, but Autolites in my Ford. Chris, hopefully you can change up your schedule- I was looking forward to meeting you at GL. |
Riley
Maybe the accelerator pump needs adjusting, how do you do that?
79nautique
good thing you didn't go two weeks ago you would have gotten ran over out there floating. Quite a few go fasts where out there making it a mess.
