driveshaft length |
stepper459
Senior Member Joined: June-17-2007 Location: United States Status: Offline Points: 349 |
Posted: June-18-2007 at 4:03pm |
Thanks for the reply... I think you're right, it's no problem at all. I pulled the shaft and checked it with a dial indicator and it's not warped or bent at all (at least not beyond spec) so I guess my next step is engine alignment. I'll put up a post when I get that done, just for others' reference.
459, It really shouldn't be a problem. You should still have plenty of room between the prop and the cutlass bearing. If it isn't a double taper shaft, you could even put it in the trans coupling a 1/8" shy.
stepper459
Any opinion on whether a driveshaft that's 3/16" shorter than the factory spec would make a difference? Vibrate? Do damage? Do nothing? My boat is an 89 supra - before you all attack me for not having a cc, I love cc's, they're the best boats in the world... I just got a deal I couldn't refuse on the supra - same engine & trans. as an '89 2001 - Ford/PCM 351w & 1.23 trans. I have a slight vibration and I've checked everything except engine alignment - that's next. But I noticed that my driveshaft is 44 and 3/16 while the factory spec is 44.5" and I wonder if that matters at all, or if 3/16" is insignificant.
Thanks for your input. |
