Installing stereo in 89 Ski Nautique? |
Author | ||
jo-e90
Gold Member Joined: March-16-2011 Location: Midwest Status: Offline Points: 659 |
Posted: April-28-2013 at 12:52am |
Can someone please post pics of where you put your 12" subwoofer with enclosure?
1997 Sport Nautique
inglesideshawn
Senior Member Joined: April-03-2009 Location: ingleside, il Status: Offline Points: 203 |
mine are in the pass base, and under the bow,it sounds great...
and when did the site change how to post pictures?what did i miss? |
1989 nautique
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
Worst install?
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
I have the cut outs for those in my 1987, They make for easy access to my dock lines stored there without having to lift the seat. I did not replace them because I did not want the bases teathered. I mounted them as described earlier.
1987 Ski Nautique |
Hollywood
4x10s
dochockey
Gold Member Joined: September-16-2009 Location: Colorado Status: Offline Points: 638 |
I bought my boat new from my local dealer and when the stereo question came up I said yes I would like one. It came In the glove box where it has a cover and you can lock it, they just put two speakers under the corner seats in the back.
1989 Teal Ski Nautique
1967 Mustang Harris Float Sunfish |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
It seems that you wish to keep your setup along the factory lines, but speaker technology has come a long way since then. I'd look at fitting a quality speaker behind the old "factory" grills.? It will give you better sound with "factory" look. |
rosconole
Gold Member Joined: May-10-2008 Location: United States Status: Offline Points: 759 |
I think 6.5 polk coax is what they use now , that or JL audio coax should give good quailty sound and hold up good in florida where I am as well. I have polk separate 6.5s in mine I really like them, caught them 159(300 usually) for pair on amazon couldnt pass up that deal...I just bought last years sony marine best they had with ipod connection for 159. that was 299+
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
89Ski_Nautique
Senior Member Joined: May-26-2009 Location: Windermere, FL Status: Offline Points: 160 |
The stereo is safely mounted in the glove box which I believe was one of the locations used by the factory.
Does any one know what were the original front speakers both size and manfacturer, that were installed at the factory or by the dealers? I want to stick with the original factory setup. I currently have a set of 6.5" Jensen Marine (Coax or Dual Cone??) which are starting to distort when played at a nominal volume level. Thanks Randy |
Bama Nautique
Senior Member Joined: February-26-2010 Location: Tuscaloosa, Ala Status: Offline Points: 153 |
Good topic 89Nautique2001. I also want to install a stero system in my 89SN2001 but dont want to cut anything. If I did have to cut something then I would put mine in the glove box but that makes operation difficult when driving boat. I also dont want to cut anything for speakers. If there are any pics out there I would love to see them. Thx. |
rosconole
I'll take some pictures of my 89 , used to have it under wheel to right of steering box then moved it stupidly to glove box , it mounts nice there but if you dont have the cover on the glove box or it happens to rain...it claims the life of radio.. i have polk 6.5 separates in front and in back and 12" polk sub with 5 channel kicker amp. sounds good. check out onlinecarstereo.com got some nice deals on there.. I would definately go for remote setup. I dont have one yet but thats my next project.
dochockey
This post started in 07 Mine is in the glove box but I have a remote control so I can do my adjusting without getting out of my seat Is the roll for when your cruising a high speed a you do a power turn and the people in the back mess their pants cause they thought they were over board LMBFAO
kapla
good use, to wash out the drull when looking chicks!!
<a href="">1992 ski nautique
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
Is that a roll of toilet paper?
Hollywood
The wired remote pod is screwed to the plywood where the bag snaps to.
TRBenj: Yes. |
OverMyHead
I used 3/4 plywood, carpeted the plywood on the front mounted speakers to the back with an appropriate hole cut out. I then removed a teak strip in front of the rear seat and countersunk screws through the gunnel into the ply. I then re-secured the teak to hide the screws. skis still fit behind, if you so wish, I have seen boxes that were way cooler but this was fast and easy. I am thinking about building new boxes combined with beverage holders in the future.
1987 Ski Nautique |
Chopper
I looked at mounting the head unit in the dash when I had my 89. It would fit due to the avove mentioned factory allowance for the twin post unit. However I decided to mount it in the glove box. more secure, and I figure the passengers can be in control of the music.
A dash mounted remote would be ideal. |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3397 |
Ecactly what I did when I got my new dash panel... Used to be mounted in the dashpanel, but now it's safely mounted in the glove box. |
ben
Newbie Joined: October-09-2010 Location: South Africa Status: Offline Points: 4 |
I have a fully waterproof radio because I want it away from the steering console. I am not yet entirely sure where t omount it but I like the original look that will be cluttered with the installation of a modern radio.
Darrel
Senior Member Joined: June-16-2004 Location: United States Status: Offline Points: 340 |
Why not in the glove box with a remote on the dash pod. Gets it out of harms way and still easy tuning.
gn6027
Senior Member Joined: October-15-2006 Location: Ohio Status: Offline Points: 192 |
Mine is mounted in the same place as Dank in my '87 2001. There is a ton of space behind it as well. If you get your head up under the dash (take out the drivers seat), you might be able to see where there is a pre-form cutout for an older two-post radio. I cut mine out and installed a new DIN mounted radio last year.
I have two 6x9 speakers mounted in the rear seat tubs facing forward. I have some 6" round ones that I want to mount as well, but I don't want to cut into the vinyl, so I'm making some SS brackets to mount them under the gunwhales. |
GN6027
1987 Ski Nautique 2001 |
duffnit
Senior Member Joined: October-12-2005 Location: United States Status: Offline Points: 235 |
89, Dank installed his where I plan on moving mine. I currently have the unit mounted under the dash (right of steering box), but I'm tired of hitting my knee on it. There is a cut out behind the face plate for a head unit. I installed some Polk enclosed outdoor speakers under the gunnel by removing the teak strips and bolting 2x4's under the gunnel, and then putting the teak strips back on to cover my bolts. I used the 2x4's to mount the speaker brackets to and called it good. I put a 10 disc changer under the bow and that has worked well. Now, if I could find a small enough cover to fit the face plate mount I could call it done. d
Danny
"no offense- but the rate at which you spread bad information is very impressive" |
Dank
Senior Member Joined: April-05-2005 Location: Austin, TX Status: Offline Points: 296 |
It's a little hard to see in this picture, but I have my stereo mounted on the dash on the left side. I have two speakers on the front left and front right of the dog box and two under the gunnels just in front of the back seat. It's an '88.
"I don't know what the world may need, but a V8 engine's a good start for me"
89Nautique2001
Newbie Joined: May-07-2007 Location: Lake Delhi, Ia Status: Offline Points: 31 |
Where is the best place to mount the stereo. I would like it on the dash on the lt side, is there room for it there? I would have to cut a hole & do not know if I want to do that. There is a place in the glove box, but would be a pain tuning it from there. Also, where would be the best place to install speakers in the rear section of the boat? Any photos? Thanks
------- They are only original once! ------
