  New Posts New Posts RSS Feed - Vacuum bagging stringers?
leo0648 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leo0648 Quote  Post ReplyReply Direct Link To This Post Topic: Vacuum bagging stringers?
    Posted: July-09-2007 at 8:26pm
We had to do quite a bit of vacuum bagging on some Boeing 787 parts. Honestly, it is a lot of work. It is a boat not an airplane. Just do the regular hand lay up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2007 at 11:16am
Mike, Typically vacuum bagging is used for very complex shapes or where clamping can't be done. I think on the stringers it would be more work that it's worth. They can be wet layed up without a problem.
69 Mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69 Mustang Quote  Post ReplyReply Direct Link To This Post Posted: July-06-2007 at 12:37am
In researching my stringer project I came across the vacuum bagging technique. I have a little experience doing wet lay up but not a lot. My questions are:
Is it possible to set up stringers for vacuum bagging?
Is there any advantage to vacuum bagging for a stringer application?
As always, thanks in advance,
Mike
"Where the **** are we?" Amelia Earhart. July 2, 1937
