  New Posts New Posts RSS Feed - Anyone ever use Poli-Glow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: Anyone ever use Poli-Glow?
    Posted: July-20-2007 at 8:30am
Roy, First do a on site search on buffing and do some reading. There are some threads that get detailed. If you then have some specific questions get back to us. The actual technique of holding and moving the buffer is a tough one to describe. I think it may be something you will need to try and just get a "feel" for.
Don't worry about 79's concern about your marks on the boat. Everyone has been there and he has too!!
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2007 at 2:21am
why are you banking into the docks does your reverse not work or does the driver not know how to drive and dock a boat, you should never touch the dock, well unless your toast but then I've done some of my best docking waisted.
you will want to remove the marks before you try and buff the hull. depending on jow bad it is you might just have to wet sand it to get the shine back but try buffing first little easier and quicker than wet sanding.
LakeBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LakeBoy Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2007 at 12:38am
Thanks for the feedback.
Anyone on the basics of buffing?
Tools?
Compounds?
Where to start?
Also, how do you get the rub marks out on the side of the hull from banking into docks? There are not scratches, but rubbed on material from dock sides, fenders, etc...
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2007 at 11:47am
Originally posted by keegan99usa keegan99usa wrote:
So for a quick fix, you just spray the hull with WD-40? Or at lest it will give the look of what it will look like after buffing out?
If a person needs to wet sand, what grit to start with and finish with. Our local car parts store has some 1000 grit, 1500, and 2000. Is that enough, or should Istart with 2000, and find something more like 4-5000?
Thanks
Dan
This all depends on your buffing and compound. You can even start with 600 on the bad spots and go up from there. If you have a decent 9" industrial buffer (with a very good pad like a 3M 2+2) and some good compound it will easily take out anything left from 1000. Compounds are pretty much what ever someone likes and has good results with. It does take some experimenting. I happen to like Meguires.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2007 at 11:23am
all i can say is try it, but i dont recommend it
keegan99usa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keegan99usa Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2007 at 10:56am
Thanks
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2007 at 9:53am
If you take some wd-40 it will do the same thing, its great for a last minute shine and will last for a week, all it does is hide the oxidation for a couple of days. To date i have not found a product that removes oxidation from a boat except for some good old elbow grease and rubbing compound and time
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2007 at 8:02am
LB, There have been other people who have been sucked into thinking this would be the solution to faded gel. They have reported the same results as you have. Nothing beats buffing it out! Wet sanding may not be required. It depends on how bad the fading is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LakeBoy Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2007 at 2:50am
I made an application to my dull gel-coat with Poli-Glow. I followed the instructions carefully and it looks like crap.
The application is done using a foam applicator. The finish, while shiny, looks like if you took varnish to your heirloom furniture and applied it with a foam block: very streaky and uneven. It looks especially bad on the large areas like the bow or stern.
I have read some threads on wet-sanding to get the finsh back, but I am not ready to go there.
Any advice, comments?
