OJ prop shaft seals ? |
Posted: July-20-2007 at 4:16pm |
Thread on prop pullin and installing
This should do it but I totally disagree with the person who is greasing the taper. DO NOT GREASE. It is the taper that transmits the HP and torque from the shaft to the prop. If the taper is fit properly (you should check it) you wouldn't even need the key. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3365 |
No, thats a prescription to f it up. |
River Rat to Mole |
85Nautique
Groupie Joined: April-30-2007 Location: United States Status: Offline Points: 69 |
this is a stupid question can someone take pics of how to put a new prop on.
Is it just put the prop on the shaft and tighten the bolt and use that to press the prop on and cotter pin I just never have done it and now i have two new props on the way because the two i had a bent |
The Dude
Platinum Member Joined: October-19-2004 Location: Houston Status: Offline Points: 1335 |
Pete, is the gortex pretty maintenance-free? Do you still have to allow the slow leak to lubricate the shaft?
bchesley
Senior Member Joined: October-29-2004 Location: United States Status: Offline Points: 188 |
I talked to the guys at skidim about both systems and they recommended the PSS for an older boat with an original shaft. They claim that the OJ seals will wear our fast on a shaft that has had a packing system run on it for any length of time. If you ave a new shaft there is nothing to worry about. It makes since so I bought the PSS and will be installing it in a week or two. I will post results.
Brad |
2001 SAN
"Python Powered" |
SkiBum
Just converted to the OJ. Is was an easy install. Works very well. Just as good as the PSS I would suppose and a bit cheaper.
They are both pretty much the same but I would simply install the good teflon Gore-tex packing and be done with it. It's a lot cheaper.
kevman38
Newbie Joined: August-29-2006 Location: United States Status: Offline Points: 29 |
Is anyone using OJ shaft seals. There is some info about the pss ,but not very much on the OJ.
