  New Posts New Posts RSS Feed - 351 Thermo Electron
351 Thermo Electron
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Topic: 351 Thermo Electron
    Posted: April-27-2005 at 11:56am
MMA,
If you want a copy of a manual, call this guy:
Dan Labadie 704-400-3116. He's got a 72 Mustang with a Palmer, and either still has my manual or made a copy of it. He'd be glad to make you a copy and send it to you most likely, if you just tell him you talked to Reid. I found the manual on the net. Just found this again now. Check it out: http://www.marineengine.com/manuals/palmer/
ReidP
1973 Mustang
mma3447 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mma3447 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2005 at 3:57pm
Did you have any luck finding a manual? I have a 73 Nautique with the Thermo Electron engine.
mma3447
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2004 at 11:54pm
Like Duck Soup stated, they were definitely related. Once the T.E. engine marketing name came on the scene, I think sometime around 71-72, the Ford engines were red and carried the Thermo name while the Crusaders were blue and I believe shifted to the GM block. There were plenty of blue Ford Crusaders prior to that. But that's from what I've observed only. I know there's someone out there with an old brochure and I think e-bay would be a good place to stick an inquiry. Good luck and how about some boat/engine photos.
ReidP
1973 Mustang
duck soup View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote duck soup Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2004 at 7:21pm
Thermo Electron is or was the parent co. of Crusader Marine Engines which is still in business. They mostly used GM blocks but like other companies probably also used ford blocks at some point. Check out their web site at crusaderengines.com.
Richard View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2004 at 5:45pm
Can anyone direct me to a maintenance manual for a 351 Ford Thermo Electron engine. I have a 1974 Ski Nautique, and it seems that this engine is somewhat of an orphan.
