raw water pump |
Guests
Guest |
Posted: August-17-2007 at 7:39pm |
the previous owner must have stripped one of the blots and has finally gave way.tried having it machined/tapped and in the process it cracked in half.went out yesterday and tried it with just one blot and no success..pulley was all over the place.actually went into limp mode..hate tro spend 275 on one this late in the year
Ryan, What is wrong with your pump? You do have one don't you? If you do have one, I know you are pretty handy so you may want to consider rebuilding. If the housing isn't busted open, then all they need is bearings, seal and impeller. There is a thread on a parts source.
Guests
Guest |
for a 1994 is needed
