Reid this is it |
JoeinNY ![]() Grand Poobah ![]() ![]() Joined: October-19-2005 Location: United States Status: Offline Points: 5697 |
![]() ![]() ![]() ![]() ![]() Posted: September-17-2007 at 1:08pm |
Well 325 or 350 it sounds like she is coming along pretty good, I agree she is a little too pretty to beat like a standard Windsor block engine especially considering you have a few other options when your looking for all out speed. -Joe. |
jbear ![]() Grand Poobah ![]() ![]() Joined: January-21-2005 Location: Lake Wales FL. Status: Offline Points: 8193 |
He needs no encouragement.
john |
"Loud pipes save lives"
reidp ![]() Platinum Member ![]() ![]() Joined: December-06-2003 Location: Mooresville, NC Status: Offline Points: 1804 |
John, please don't encourage him.
Score one for MM!
john |
MaddMarxx ![]() Platinum Member ![]() ![]() Joined: June-29-2006 Location: United States Status: Offline Points: 1741 |
102...wow..parts were falling off his boat at 45mph before, I wonder what happen at 102, I know one thing he wont have to worry about his hair blowing around!
p/allen ![]() Gold Member ![]() ![]() Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
Reid I would suppose with 650 hp. you would be pushing close to 102 mph . If my educated guess is right . I figure double hp. = double mph.
But then again I did graduate 5th grade. |
RainDog ![]() Platinum Member ![]() ![]() Joined: February-21-2007 Location: Mke/Grn Lake WI Status: Offline Points: 1387 |
Reid,
I got 2425 lbs shown in the doucumentation I received with my Classic. |
Sorry John, but no ski pole in the Classic, go figure. So what would we tie the ropes to, Backfoot100 Eddie's forearm maybe? But then he couldn't be one of the footers.
Joe, I WAS hoping 340-350, but I feel the boat would be running faster if so, and that's why I dropped my estimate. The engine made 320-335 in a car back when, and I've got the same .480-490 lift cam spec as the 335hp model, plus an intake and slightly better heads and same 10.5 CR. The boat supposedly does weigh about 2400 based on a 'cuda, but I've never seen an actual Classic weight in print. We're still tinkering however, but I'm trying to contain myself from beating on it like we do the Mustang. |
67 mph in the classic would be my guess, slight motor box modification required. I bet that 390 is pushing 350
Alot. We did 6...do I hear 8?
john |
Pat, Those suggestions were a joke right? If that engine had about 300 less HP those would both be great ideas however.
EDIT: Speaking of the Classics, our 390 is finally running up to par with some hours on it and a 4 blade OJ from Doc. So if 330 HP will push one 51 mph, what do you reckon 650HP would do? |
Why would you have to make it reverse rotation ?
Get a Classic with the steering on the left side . Or a 1:23 - 1 trans and prop it right . |
Everything looks to be water jacketed except the turbos, worst case we could water cool your motor box but I hightly doubt it would be a problem. You will need a huge prop but it will slip a bit and by then your building boost. Might have to give some consideration to that when your specing out your rr roller cam though to make sure you can jump on plane.
It looks and sounds like a seriously done right motor, I can't imagine the reserve |
Not that I would even consider it, but wouldn't that thing make ungodly amounts of heat and pretty much cook an engine box, or no? I see it moreso in a I/O boat with a large engine compartment or maybe a flatbottom exposed-engine scenario.
And Joe, while I'm with you 100% on the torque, I still see it possibly being a slug out of the hole, as you're gonna prop it larger for the max rpm gains resulting from the turbos. In a car you have the benefit of multiple gears to compensate. Interesting. |
Its a 460 ford, turbo lag isnt going to be a problem because even with the lower compression that thing is going to have torque to spare on the bottom end.
Reid should buy it and convert it to RR... sounds like theres a company that will make some custom reverse rotation roller blanks.. |
eric lavine ![]() Grand Poobah ![]() Joined: August-13-2006 Location: United States Status: Offline Points: 13413 |
For sustained runs the turbo is an excellent choice but not for ski boats, in a ski boat a super charger is the way to got as 79 said earlier, the turbo lag is problem. a turbo charger doesnt have the ability to compress air as does a roots type supercharger, because of this you want to run low compression pistons because it kicks up the compression ratio, a rotary screw air compressor is a good example of a roots type compressor if you are familier with them
62 wood ![]() Grand Poobah ![]() ![]() Joined: February-19-2005 Location: NW IL Status: Offline Points: 4527 |
Chuck, All the SS' I had ( and still have) are Chevy powered... but the 'Cudas were Nopower...I mean Mopar... now Im really confused.... ![]() |
8122pbrainard ![]() Grand Poobah ![]() ![]() Joined: September-14-2006 Location: Three Lakes Wi. Status: Offline Points: 41040 |
Tull, If you look at this picture, you will see that the cooling water running through the manifolds is bypassed around the turbos to the exhaust riser with the short piece of hose. No water through the tubos. ![]() |
The Lake ![]() Platinum Member ![]() ![]() Joined: May-13-2005 Location: Lk Winnebago MO Status: Offline Points: 1157 |
Now Steve, come on, with that SS you need to start thinking Mopar!
![]() Chuck |
too bad its not a chevy...
Thanks Pat. I was actually in the truck making a beeline for Phoenix when I found out it wasn't reverse rotation. Oh well. Sho 'nuf is purdy though.
i think it would convert it to steam, the water would not cool it fast enough,I cant remember on the diesel boats on how the water would bypass the turbo's, but it did, we had 3 engines with twin turbo chargers, we could not get the boat out of the hole we tried everything, the engines would come up to about 1200 rpms and stay there and blow smoke. Finally what we did is we ran 3 air vent tubes down to the top side of the props to airiate the props, when those turbos spooled up you thought you were in the space shuttle
tullfooter ![]() Grand Poobah ![]() ![]() Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Excuse my ignorance, but why would a turbo not allow you to run water through the manifolds? Would the water ruin the drive impellers of the turbo, or help drive the turbo?
Hopefully this ? doesn't fall into the "dumb ? of the month" Lefty |
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
phatsat67 ![]() Grand Poobah ![]() Joined: March-13-2006 Location: Indiana Status: Offline Points: 6149 |
Turbos are awsome:) but a supercharger would be 500 times easier in a boat because you could still run the water through the manifolds. There was a vortech stetup on Ebay not to long ago for ford marine engines:)
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
nice too bad it's not a supercharger for the low end grunt, but man the top end has to be wicked.
Reid this is just what you need . Better jump on it . It looks cheep .
Ford turbo Big Block |
