  New Posts New Posts RSS Feed - Help! My Boat Sank!
Help! My Boat Sank!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Topic: Help! My Boat Sank!
    Posted: September-25-2007 at 4:47pm
Originally posted by 79Tique 79Tique wrote:
Anyone know if the 94 and newer boats with the composite stringers have any wood in them at all?
I dont think they have any wood in them at all. My uncle's '93 has composite seat bases.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: September-25-2007 at 4:17pm
Even though you changed the oil a few times, Tim's suggestion of kerosene might still make sense. Using kerosene or engine flush will cut the oil/water gooey stuff (nice technical term there) that might still be in the engine. Oil alone is not good at combining with and removing the water/oil residue.
I sank one of my boats and had a lot of water in the oil, took these steps and its been fine since.
79Tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: September-25-2007 at 3:20am
Work to live, not live to work.
farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer Quote  Post ReplyReply Direct Link To This Post Posted: September-20-2007 at 12:02am
My '77 mustang17 is carpet over fiberglass,no plywood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2007 at 11:20am
Originally posted by stang72 stang72 wrote:
On the earlier 70's boats (both my 72's)they glassed over everything with a chopper gun , but added a plywood floor over the top of the glassed in floor that is screwed in...are you saying that carpet is put on directly over the glass on the 2001 nautiques???
Yup, and my '90 is built the same way. The 1/8-1/4" glass is is laid on top of the foam, and the carpet goes directly over the glass. The only wood in the floor is between the motorbox and battery box and the removable panel behind the motor.
stang72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: September-18-2007 at 1:23am
99...glad the thing is running...that's good news!Checking the foam can wait a bit, until you have time! If you get her back in the water and it runs the same top end etc...the foam may not have soaked...when foam takes on water it can add up to several hunderd pounds...it would feel like you have a few heavy passangers aboard! Perfomance loss is noticable because of the weight!
stang
The Super Air
nautique99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique99 Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2007 at 9:05pm
Thank you to everyone who offered their help and expertise. I did change the fluids several times and started the motor without a problem and then changed the fluids again.
I'm getting the boat to a marina to have the motor and transmission checked out. I assume the starter will quit on me at some point but that's a relatively minor problem.
The bay I ski in is brackish, so the salt isn't as tough as pure sea water, hopefully it's had a bit less of an effect. I'll deal with the floor and foam at a later date.
Again many thanks to everyone for their help, I hope I can return the favor some day!
bchesley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bchesley Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2007 at 5:14pm
No wood just glass over foam from motor back. The only wood is up at the seats in front so there is something to screw to. I reglassed my 83 and cant imagine that anything changed in a few years.
2001 SAN
"Python Powered"
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2007 at 12:55pm
Tim...yes that is what I am saying...must cut through the glass! I assumed there was a plywood floor over the glass like on earlier SN's...either way a hole is cut through the glass into the cavities to check the foam.
stang
The Super Air
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-17-2007 at 12:35pm
As far as finding out if the foam is soaked....you will need to remove the carpet and remove the floor( usually screwed in)...
Not in '85, I dont believe. That floor will be covered in fiberglass. The only way to check the foam would be to cut a hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2007 at 12:29pm
As far as finding out if the foam is soaked....you will need to remove the carpet and remove the floor( usually screwed in)...once the floor is out , you can sample areas to see if water has entered the cavities between stringers etc...cut a small hole (size of a quarter or so)through the fiberglass that floor was over and probe with a screw driver (or what ever)...work it down to the hull...if there is soaked foam,it will be very noticable. Do the same in several locations...if it's not soaked , you can seal the openings back,put the floor back and be done! If you need to remove foam,there are bunches of posts on the subject...and yes it is a job you can tackle! BTW...if the floor is going to be replced...don't toss it away...use if to as a pattern for the new floor.
stang
The Super Air
69 Mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69 Mustang Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2007 at 4:36am
I'd do a pre-emptive strike on the starter - just get a new or rebuilt one if it is in the budget. Have the old one rebuilt by someone who does marine starters and keep it as a spare.
"Where the **** are we?" Amelia Earhart. July 2, 1937
Post Options Post Options   Thanks (0) Thanks(0)   Quote stang72 Quote  Post ReplyReply Direct Link To This Post Posted: September-15-2007 at 3:34am
All others have offered good advise...I suggest move quickly and don't freak out just yet! Stringers will be fine ...it take years to rot! If there is soggy foam...remove it and dry things out...run some air(warm air heater)in the boat and like others have said...oil change and tranny fluid change. Starter may or may not recover.
stang
The Super Air
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2007 at 7:18pm
Take the valve covers off and pour kerosene down both sides of the engine, it will push the water out. Then chase it out with oil.
Tim D
Darrel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrel Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2007 at 6:04pm
I would dump the oil in motor and trans once or twice, spray the starter with WD40 heavily. I doubt there is water in the cylinders but if there is you are going to have to pull the plugs and turn it over to pump it out. A nice squirt of marvel mystry oil in each cyl. Then run it hard to heat up the motor and evaporate the moisture. Then change the motor and trans oils again. Dont wait. Good luck.
I'd rather have a drink on the rocks in the boat than have a boat on the rocks in the drink. Been there, done that, no bueno.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2007 at 5:53pm
Salt water? do you have insurance? if you do see what they cover so the repairs get done properly, they should allow complete tear down of items and re-seal and possibly wire harnesses if affected, aint nothing worse than something that has been sank in the salt.
sorry to hear btw, dont be afraid to use your insurance..thats why you have it,
Eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2007 at 5:20pm
Yikes. Your engine and tranny are probably salvagable if you dont run the boat and get the oils changed ASAP. Be sure to flush them several (5+) times. Its likely the starter will die an early death since its been submerged.
The floor is made with fiberglass, it wont hold water. If there were any cracks in the floor then its likely that water made it below the deck. However, with a boat that age, its pretty likely you already have some wet foam- especially if it stays in the water all the time.
I say get the motor straightened out and take it from there. If you end up needing to do some floor/stringer repair, there are many threads on this site that can help you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique99 Quote  Post ReplyReply Direct Link To This Post Posted: September-14-2007 at 5:05pm
Well, it finally happened. I returned to my 85' SN after 2 weeks away to find that I couldn't read ski nautique on the side of my boat anymore.
It was more than half way submurged in the bay I keep it in. After doing a lot of bailing and then letting the bilge do the rest, I got it floating again and found that the packing gland on the drive shaft went. Enough so that the battery died after what must have been endless bilging
First the engine: Partially submerged up past the oil pan, fully above the transmission. Can they be cleaned/flushed out and used again or do I need to rebuild/replace?
The hull: I have to imagine that since there was about 6 inches of water sitting above the floor that all the foam under the floor is holding water and ruined. Is it a difficult procedure to cut out the floor and foam and replace? Should I be concerned about the stringers? I'm very handy, is this something I can do myself.
Also if anyone can recommend a repair facility on the east end of ong Island NY it would be greatly appreciated.
Thanks for your help...
