Bearings for CC #2 Trailer |
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7957 |
Posted: September-24-2007 at 11:30am |
More pics will be coming. The boat needs to be wet sanded, but for now we used some Collinites Boat Cleaner on it and waxed with carnuba and it looks pretty darn good.
It's a cool little boat. It fits in the garage between the 2 Malibus better than the 14' aluminum weI have. |
jbear
Bruce: Nice find! But ya gotta post a better pic than that! C'mon man you know how we are on here.
Sounds like you got a good start on it already. Keep us nosey guys posted! john |
"Loud pipes save lives"
Riley
http://i162.photobucket.com/albums/t270/88Skier/67Mustang9-22-2007005.jpg
This was posted on CCF a couple weeks ago. It was just what I was looking for. A project that is within my capabilities, (I hope). I love the 66-67 CC. The model and color are perfect. It's got a gas pedal, which is what I wanted, and a CC trailer. It's got a 100 hp Interceptor straight 6. I don't care that it is a "pooch" because I've got 2 other ski boats, one which is a rocket. The gel coat is in really good shape with few scratches. It has some kind of vanish on it that has worn off in spots, but is thick in others. I believe I can make it look pretty decent. The boat was dirty. The picture is after it got its 1st bath when we got home last night. I forgot my camera today, but we took it to the camp, where we proceeded to clean it and then take it apart. I took the interior out, ripped the floor out because it was rotted and wet. We then took out most of the foam which was soaken. I think the stringers are fine, and it just needs some of the strapping replaced. After I get all the foam out I will figure just how I am going to do the floor. The tranny needs to be rebuilt. I figure maybe by next summer sometime, I will have it not mint, but pretty respectable for an original boat. |
Bruce, Glad to here you got it and you had a safe trip. Now the important issue is when are we going to see some pictures??
Riley
I made it back to Maine from New Jesey without any problems. We are now the owner of a 1967 Mustang.
1973Skier
Newbie Joined: September-12-2007 Location: United States Status: Offline Points: 9 |
After sanding the rust off the spindles on my #2 I calipered the bearing size at 1" both inside and outside. Be sure to properly seat the new bearings by turning the wheel while tightening the nut to the torque specified by the bearing mfg. Nothing like a sanded spindle to make things go better
If it doesn't need work, I can't afford it!
boat dr
My # 2 has 1"x1" this traslates to a 1in. straight axle.
It could be a 1"x 1 1/16" these were the most common way back when.. The newer sizes are different.......... |
Riley
I figured as much, but was hoping someone would say "Napa #xxx". I'll post when I get back. |
backfoot100
Riley, there are lots of different sizes of bearings. If you're concerned, I would say to take tools and repack them before you leave for the trip home. You really won't know what size they are unless you remove them first.
Definitely let us know what you got!!!! |
Eddie |
bmiller
Senior Member Joined: June-05-2006 Location: United States Status: Offline Points: 234 |
I feel your sense of peace of mind.When I bought my boat I had to go to Texas to get it and I live in Northern Kentucky.When I saw the tires on mine I was sweating it also but made it abck without a problem.Good luck on the boat.What did you buy?
Riley
Larry, I have found a boat and am going to get it this weekend. I'll post on Monday, once it's mine.
bmiller, Owner says they are good and is installing new buddy bearings. I will grease them all the way home. Owner says I won't have a problem, but if I had a new set of bearings in the truck with me, it would give me some peace of mind. If I don't need them, I can return them on Monday. |
bmiller
I can see your point.If it has buddy bearings on it you can shoot some grease into the hub and hope for the best.When was the last time the trailer was on the road.Did the owner say the bearings might be going bad?
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
Bruce, Did you buy a new boat? I know you've been looking. |
Riley
Good idea, but my situation is that the trailer is 5 states away from me and I would really like to have a spare set in case I run into problems on the road.
bmiller
There should be a bearing number on the bearing itself.If not,you can take the old bearing to any decent autoparts store or a industrial belt and bearing store and they can put a micrometer on the bearing and measure to see what you need.
Riley
Anyone know what bearings this trailer takes?
