  New Posts New Posts RSS Feed - Gas Tank Survives Fire
jcawley3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jcawley3 Quote  Post ReplyReply Direct Link To This Post Topic: Gas Tank Survives Fire
    Posted: October-17-2004 at 3:18pm
not sure what your tank was made but my '86SN tank did not fair so well. It was full of fuel and at the top right corner the tank split and thats when it "really got burning good"
WRoll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WRoll Quote  Post ReplyReply Direct Link To This Post Posted: October-01-2004 at 8:41pm
Polypropylene melts at 320 degrees F, the fire was a lot hotter than 320 degrees it melted every aluminum component in the garage which means that the temperature was in excess of 1000 degree f. The interesting part is the tank did shrivel up to about half of it's original size.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2004 at 3:57am
I beleive its polypropylene. It probably survivrd because it was full of liquid that kept the tank from reaching a high enough temp to ignite. If you take a paper cup (not plastic or styrofoam) fill it with water and put an egg in it you can boil that egg in an open fire. The water never exceeds 212 degrees and paper doesn't ignite until it gets to 450.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WRoll Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2004 at 4:51pm
My 1991 Ski Nautique was burned in a garage fire. All that remained was the motor and the floor from the engine back. What is truly amazing is that the gas tank survived the fire with gas in the tank. Anyone know what material the tanks is made of that makes it resistant to fire?
