  New Posts New Posts RSS Feed - voltage drain
voltage drain
IrishFooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IrishFooter Quote  Post ReplyReply Direct Link To This Post Topic: voltage drain
    Posted: October-09-2004 at 6:18pm
I recently replaced the radion in my boat and found that it has a stting for the clock that keeps it quite bright and also draint eh battery. I found out the hard way.
1979 Ski Nautique
jameski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameski Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2004 at 6:42pm
The radio should not drain the battery in a week. Have you checked your battery? The best way I've found to find a drain is to work at night disconnecting one wire at a time and looking for a tiny spark (may be very hard to see in the day light). But it sounds like you have already tried that. Maybe you just need a new battery.
current boat
94 Sport Nautique
previous boat
78 Martinique
BT View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote BT Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2004 at 6:10pm
Yeah, but I never use it and the faceplace is always off. I know that it could still be wired but with a viable battery, should it drain down that much so that the boat doesn't start? If that's the culprit, I'll have to change the wiring
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2004 at 5:48pm
Do you have a stereo? It needs current to save your settings.
Tim D
BT View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote BT Quote  Post ReplyReply Direct Link To This Post Posted: September-24-2004 at 12:20pm
Hi all,
I have a GT-40 that is losing the battery charge after sitting a week plus. When checking the electrical system with everything off, I am seeing a draw on the battery of about .3 to .4 volts. I have checked grounds, disconnected starter and alternator and one by one disconnected wires at the dash to no avail. Any help would be appreciated.
