  New Posts New Posts RSS Feed - Completly Ignorant Trailer Brakes
anthonylizardi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Topic: Completly Ignorant Trailer Brakes
    Posted: October-30-2007 at 10:04pm
Glen, thank you so much. I should be able to do it with this information.
gn6027 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gn6027 Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2007 at 9:54pm
Go to Dexteraxle.com and check out the Resource Library and the Products & Literature sections. You should be able to find enough info to help you out.
If you're familiar with drum brakes on a car, the trailer brakes won't be any problem. Once you get the drum off, you'll see the typical spring arrangement and brake cylinder.
You bleed the brakes by loosening a fitting on the back side of the cylinder.
Look thru the info on Dexteraxle.com, and I bet you'll find everything you need.
Here's an example of what you can find:
http://dexteraxle.com/i/u/1080235/f/Brakes/12_x_2_in._Brakes_80_res_2-05.pdf
I had mine apart last spring, and chances are, the brake cylinder is locked up.
Championtrailers.com also has a Technical Assistance section.
Glen
Post Options Post Options   Thanks (0) Thanks(0)   Quote anthonylizardi Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2007 at 8:17pm
I have experience fixing cars brakes but this is the first time I need to fix brakes on a trailer. I have surge drum brakes on my Remlin trailer. I recently purchase this trailer but I believe the brakes are not working properly. Does anybody knows where I can guide a maintenance guide for it? I tried to remove the oil cap but it won't come out. Is that just a screw type cap. How can you test the system? Or bleed them?
