  New Posts New Posts RSS Feed - New Motor -no use
New Motor -no use
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Topic: New Motor -no use
    Posted: October-19-2004 at 8:09pm
Ok ... I have the answers.
1. (main thing!!) take out old water pump impeller and replace. (The old one has been stuck in the same position for 2 years ... not good)
2. Remove spark plugs and give the cylinders a good shot of fogging oil. (yeah ..it should have been done before ..but at least this will give the upper cylinder walls some lubrication while re-starting)
3. Replace fuel filter in the fuel cell.
4. check all fluids.
5. fill gas tank
6. Start engine ... warm up.
7. drain oil and replace oil and filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: October-13-2004 at 7:03pm
I put a brand new GT-40 motor in my Nautique 2 years ago. I ran it once hooked up to a hose for 15 minutes.
That's it. I never ran it again. It's been unused sitting in my garage for the past 2 years. I did drain the gas tank.I want to start using the boat again (finally) I am concerned about starting it up and scratching the cylinders, valves etc since it hasn't been run in such a long time. Can anyone tell me the proper way to get it ready to start? Thank you,
Mike K.
