  New Posts New Posts RSS Feed - Reverse rotation oil control
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Topic: Reverse rotation oil control
    Posted: January-16-2008 at 9:56am
When I rebuilt my 351 RR the crank had the oil groves in it. The machinist said I could use any rear seal since the shaft was groved. I did get a set of RR seals anyway just to be sure. Don't forget about the front seal, that one must be RR as there are no groves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-16-2008 at 1:36am
When I did mine,the machine shop ground off the grooves and put on a speedy sleeve to build it back up.I then used a rope seal and it's worked fine since.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-15-2008 at 11:49pm
ya know something Reid... i finished a tranny just today, rebuilt and tested it and wouldnt you know it, one of the guys found the baffle sitting on the bench next to the one i was on. I completely forgot it and again i had to tear it back down...i guess it being winter i fell out of the groove
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: January-14-2008 at 2:13am
I feel your pain Eric. I had this stout 302 short block from an older CC Mustang just sitting on a stand when a buddy and I picked up this neat old red '67 Donzi 18' with a busted engine. I was in such a hurry to see this thing run that we immediately swapped a std rot cam into the 302 and installed the engine and almost immediately started draining oil out of the bilge. But it did run good as several CCFans witnessed, but we picked up a std rot 347 stroker late summer and we've been running with that since, and which doesn't leak oil. But I KNEW that Rev Rot 302 would leak when spun std, esp without changing anything oil related.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-13-2008 at 1:43pm
Dont worry Reid, i put a trans back up into a truck a couple weeks ago and between phone calls i found a very important thrustwasher in my hot tank after the fact, i have no idea how i forgot it because i do many of these just from memory.... had to pull it back out
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-13-2008 at 1:07pm
Did you guys make sure you put the flywheel towards the back (aft) of the boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2008 at 12:18am
you did what?????!!!!!!!!! I'll never forget
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2008 at 9:31pm
Now why would he go and admit that on this website. I filed it under the "what the hell was I thinking" category, and am trying to forget about it.
ReidP
1973 Mustang
Sabre002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sabre002 Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2008 at 8:46pm
Yes some cranks have a goove cut inthem to help push oil back into the motor. Reid and I found this out the hard way when we changed a motor to standard rotaion to put in a Donzi.
So what winks and f**k's like a tiger?
www.facebook.com/sabre002
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2008 at 11:03pm
The boat is a 86 Silver the block s/n is a 84 casting ,heads 85. It has 270 hrs. I found a 74 block out of a truck. The mustang guys say 69-74 blocks weigh 10 lbs. more dew to more meat in the web area. I'd like to use the old reciprocating assy. with new bearings & rings D/roller T set, GT40 or P heads a new cam , al weiand intake. ReidP had a builder out of Michigan but I lost that web site anybody have it ? I'll be in Detroit for the Autorama maybe I could drop by(and pick up a short block!)
- waterdog -
78 Ski Tique
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2008 at 10:24pm
Andy, depends on the year model.
The two piece rear main uses knurlings on the crank to control the oil. The one piece uses a special seal that has the knurlings made into the seal.This type uses a "normal"crankshaft.
Kinda like the front seal that you have now.The piston pins do not have an offset so they do not have to be rotated.All you have to have is a Reverse Rotation camshaft.
Now is the time to build that stroker motor. there is rumors that a 351/427 stroker will be at GREEN LAKE.........Food for thought............boat dr
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2008 at 10:22pm
RR oil seal
Hopefully this link will help to answer your questions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2008 at 9:56pm
351w - I'm looking for a block ,is the crank groved for the rear main seal or the seal directional? Is there a one peice r/main seal for newer blocks(reverse rotation)? The short block is still in the boat but not for long!
- waterdog -
78 Ski Tique
