  New Posts New Posts RSS Feed - Gel repair (Remix)
Gel repair (Remix)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Topic: Gel repair (Remix)
    Posted: March-20-2008 at 5:42pm
Dave, even on new boats you can see where they repair when it dosn't come out of the mold perfect.My Dads Shamrock had some and I believe my Mustang does also.Just be careful you don't come up with this color,it's already taken
[/QUOTE]
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2008 at 1:11pm
Originally posted by LaurelLakeSkier LaurelLakeSkier wrote:
Give these guys a try. They do a good job of matching the original color.
Spectrum Color
Depending on how much fading you have, you should get a pretty close match. I would suggest staying away from the kits that have you mix your own color from tints.....I've tried and found it next to impossible to even get close to a match.
Thanks for the reference LLS.... Problem is they don't make kits for a 76'. Matching is the only way to attempt these repairs. Pete's right, I think you'll always see it to some degree...
Moj'
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2008 at 1:07pm
Pete,
You leave me no alternative than to paint the hull green then LOL....
Moj'
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2008 at 7:46am
Pete I know it's way too early to ask,but would you consider bringing your Mini-Craft color wheel to Green Lake? I'd like to fix some chips etc,and I thought I'd try to get at least close to the color.
Gary, I don't have a color wheel. I borrowed it from a friend. He's up north and does all of Watercraft Sales glass work. I will probably see him again before GL and see. He is also a member here but doesn't post much. Dial up in the north woods of Wisconsin isn't fun!!!
With any luck, he'll have his Torino done and will be at GL this summer!
LaurelLakeSkier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaurelLakeSkier Quote  Post ReplyReply Direct Link To This Post Posted: March-20-2008 at 12:31am
Spectrum Color
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2008 at 10:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2008 at 9:03pm
Dave, Real close but I'd say you would always see the repair. Some of the pros are real good at mixing but I've still spotted the repair. You could try one of the gel repair kits yourself. If you do, when adding the tint colors, use the head of a toothpick to add TINY amounts!
Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mojo Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2008 at 6:35pm
Guys,
I know I'm being redundant here, but what the hell, so I'm "a.d.d.".....
I have gouges and screw holes in the 76' and want to fill them in.. Is there a change in hell of matching the old gell, (even after wet sanding down to enhance the original color)??
What's the best/easiest filler to use..
Sorry again to rehash, but I'm bringing the boat home to start the Spring work and want to make my list...
Thanks
Dave
05' SV211 TE
73' Martinique
had:96' SNOB
had:76' Nautique
had 77 Tique
