  New Posts New Posts RSS Feed - Resin Wax Removal?
Resin Wax Removal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Topic: Resin Wax Removal?
    Posted: March-01-2008 at 7:14pm
Okay, here's the problem. The engine cover has cracks along the corners on the rear of the cover running vertical. I stop drilled the cracks and I did a fiberglass repair on them using resin and cloth. I used Evercoat Premium Resin which does have the wax in it. I've got some complex curves in the repair and I'd like to stregthen it up more but I know I need to remove the resin surface wax. Does anyone have a quick way to remove the wax other than sanding? It's gumming up my sand paper quicker than snot and I'm wondering if someone has a better way. I tried Paint Thinner and Acetone and it just laughed at me. Any Ideas?
Foot
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2008 at 7:33pm
Tim, Try some denatured alcohol. Are you wet sanding? The wax is supposed to make sanding easy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2008 at 7:50pm
Pete, No I am not. Guess I'm supposed to wet sand huh? Yeah, that's what I thought too. Maybe wet sanding is the trick.
