  New Posts New Posts RSS Feed - Teleflex Tachometer wires
Sam B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam B Quote  Post ReplyReply Direct Link To This Post Topic: Teleflex Tachometer wires
    Posted: April-20-2008 at 1:01am
I have a Teleflex tach in my 73 nautique. I am not sure the model number. But i can tell you that the face has the blue pin stripe circle. Anyway the problem is the wires are not the same colors as the tach I removed. The colors I have now are :
Red
Blue
Grey
Black
I think red is +
Black   -
Grey coil
Blue is light
I tried the tach wired like this and it didnt work properly.
Thanks Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2008 at 10:39am
Sam, You've got the tach correctly wired! What's not working properly? Bad readings? Do you have the number of cylinder jumper set correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam B Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2008 at 11:27am
Yes I have it on 8 cyl. When I start the boat the tack gues to 6000. Also when I cycle the ignition on and off the tach moves up about 200 rpm every time.
Thanks for your help. Sam
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2008 at 1:05pm
with the key on the tach should read 0, with it off it doesn't matter where it goes. Sounds like something is reversed or it's not the right resistance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam B Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2008 at 12:19am
When you say not the right resistance is there something i can change on the tach to make it right?
Thanks Sam
JUST-IN-TIME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JUST-IN-TIME Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2008 at 4:13am
you need to change the settings on the tach
www.switchbait.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2008 at 7:16am
If the tach is set on the 8 cyl, and wired correctly then there is a internal problem. I do not know anyone who does repairs on these Teleflex tachs. If you found someone who is really into electronics and is willing to take a look at it, it would be your only choice unless someone else has a idea.
Tomski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomski Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2008 at 7:52am
If it goes to 6k when the starter is turning you have an issue with a short between the start and ignition circuits. The move to 200 when the ignition is on could point to the same thing.
I had a problem with the tacho on my little car, same kind of issues. I ran a jumper wire straight from the coil to by pass the signal wire in the loom and it was fine. I spoke to an instrument specialist and he suggested putting a resistor in the signal wire and that cured it straight off.
Easily Parted From Money
