boom |
bdabj2001
Newbie Joined: April-20-2008 Location: Canada Status: Offline Points: 3 |
Posted: April-20-2008 at 5:17pm |
Would someone please advise me which boom to get for a 2005 Air Natique 206? Tower, curved pole or straight pole. I keep getting mixed advise.
Thanks kindly |
Keith
Admin Group Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
bdabj2001,
Do you currently have a tower on your 2005 Air Nautique? -Keith |
bdabj2001
Yes, it's an Air Nautique 206. I don't use the Air part when I talk about it as they don't make it this way any more. Regards
backfoot100
Personally, I would go with the curved. They seem to work better when the pylons are far enough from the engine cover and you may need the curved mount to clear the windshield frame if it sits behind the pylon. A straight mount needs to be mounted high on the pylon and is generally used on older classic boats that have the pylon right next to the engine box and the windshields don't curve back behind the pylon.
I must admit that the tower mounts are cleaner and give you lots more room for walking around the inside of the boat without stubbing toes or banging knees. They are also really expensive compared to the pylon mounts. I've never personally skied with a tower mount but from the pics I've seen of them, I just can't see any way that they can installed and removed without getting out of the boat but I could certainly be wrong on that. Somebody who has used them might know better than me. The pylon mounts are very easy to install and remove without getting wet and if you ski in early or late season cold water, that can be huge. |
Eddie |
bdabj2001
Thanks kindly for your advise Pete. I've ordered a curved from Lake Elmo Sports in the US as I can't find anything up here in Eastern Ontario. Have a great ski season...
quinner
On my 05' 206 from the pylon centerline the windshield frame is about 11" forward and the rear tower leg is about 6" aft. If you plan on using the boom off the drivers or starboard side the seat may need to be a bit forward to run the boom past.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21192 |
Sounds like the Universal Countour is going to be VERY tight, as I believe it has 8" of rear backspacing. You may have been better off with a Straight Contour (up/down curve only, no backspacing) or a Straight boom. I bought a straight boom with a height adjuster last fall and I think it will be a perfect set up. The height adjuster allows me to mount the clamp low enough to put the extended pylon on at the same time. |
wakesurfer
Senior Member Joined: April-22-2008 Location: United States Status: Offline Points: 110 |
Anyone install a tower boom on a 77 ski nautique? Curious on which boom to get. Speaking of - Anyone wanna sell a used one? here is the tower. |
