impeller install? |
jcawley3 ![]() Groupie ![]() ![]() Joined: January-31-2004 Location: United States Status: Offline Points: 82 |
![]() ![]() ![]() ![]() ![]() Posted: June-23-2005 at 1:16pm |
just got new impeller in the mail anything I should know before installing?
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5334 |
Just be sure to mark the inlet or outlet first before you pull of the pump. I but mine in backwards once and couldn't figure out why for the longest time why it was overheating. Thought I had trash down stream but doubled checked the pump and realized I had it 180' out. DUHHHhhhhh?
skyhawkflyer ![]() Senior Member ![]() Joined: February-08-2005 Location: Zimbabwe Status: Offline Points: 275 |
You'd be suprized.... that pump will go on either way.
one way it will draw fresh water, the other way it will not. (The key word here is DRAW) If your using a garden hose it will circulate. I marked my hose and pump end using 2 colored ty-raps. I also soap up the impellar good with some dish washing soap, it makes it slippery and a little easier to get it in the housing. That's about all..... ![]() |
There is a screw on the side of the housing. I believe it will face to the outside/gunnel and away from the engine. No need to mark if you look for it first and remember which way it is facing.
surroundsound64 ![]() Senior Member ![]() ![]() Joined: June-22-2005 Location: United States Status: Offline Points: 151 |
Man... I've used several different types of lube when istalling the impeller.. I saw some talked about in another thread but the best stuff is castor oil. I've never had one go bad when using that. Soaps will break down the rubber, dry it out. Never use petro based stuff either.
Soak it in castor oil for 24 hrs. And you can reuse the oil for the next time. And there should be enough space inside there for the fins to turn around IF it is installed wrong. Just look at the way the engine turns then istall the impeller accordingly. |
1981 Ski Nautique
2000 SAN Looking for a 2000-2006 SAN |
thanks
1980 Ski Tique ![]() Guest ![]() |
Basically the same as above. Remember the way the old one comes out and install the new one the same way. Buddy of mine (1986 Nautique) almost blew his engine installing it backwards!!!!!!!!
IrishFooter ![]() Groupie ![]() Joined: October-02-2004 Location: United States Status: Offline Points: 64 |
I have always used vasoline though this is a petroleum based product. Always been a breeze.
1979 Ski Nautique
Jim_In_Houston ![]() Platinum Member ![]() Joined: September-06-2004 Location: United States Status: Offline Points: 1120 |
Try KY jelly. (My doctor recommended it.) There is also some stuff called Head Job Lube but they don't sell it in auto parts stores. Just tell your wife you had to buy it for the boat. She'll understand.
Hey Jim Im in Med school and I wouldnt reccomend anyhting freaky like that. Just kidding- whatever works no matter how out of place it looks in the toolbox
1979 Ski Nautique
Jim; Please inform us if there is any other marine uses for this Kentucky Jelly. Is it only avalible in the Bluegrass state? Is it something I should keep handy around the house?
thanks for the help only took about 20 min to replaced very easy.......did not need any lube went right in
S.T. ![]() Groupie ![]() Joined: June-04-2005 Location: United States Status: Offline Points: 56 |
Jim_In_Houston,
Being in Houston, I'm surprised your doctor didn't recommend AstroGlide. It's superior to Kentucky Jelly and was developed by NASA for critical lubrication during lift-off and re-entry. It also helped the Apollo guys get their rocks off (of the moon). |
haha! |
1981 Ski Nautique
