  New Posts New Posts RSS Feed - Packing and strut bushing
pickupman96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pickupman96 Quote  Post ReplyReply Direct Link To This Post Topic: Packing and strut bushing
    Posted: May-31-2008 at 3:16pm
Sorry for the stupid question but my micrometer broke. What size packing should I be getting and what is the size of the strut bushing on my 76 mustang 302 velvet drive. Thanks alot and sorry again
1976 Correct Craft Mustang 17, 302 Ford
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-31-2008 at 7:04pm
no such thing as a stupid question, 3/16's packing? 1.125 strut bushing? for a 1" shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote pickupman96 Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2008 at 12:01am
should the shaft be 1"
Post Options Post Options   Thanks (0) Thanks(0)   Quote pickupman96 Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2008 at 1:56am
Also I need the rubber hose that connects from the brass in the hull to the packing nut. I found where the water is coming from!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote pickupman96 Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2008 at 8:58pm
anyone?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2008 at 9:19pm
well, it looks like your informing us that you found the leak and that you need a hose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote pickupman96 Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2008 at 9:22pm
I need the hose I dont know if its a special hose or what because it feels soft and flexible. I dont know it thats from the oil in the bilge or what
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2008 at 9:28pm
it is marine grade hose, i think 1.5 or 2.0, you'll have to measure it or measure the area where it attaches. your gonna have to pull the coupling and what the heck it would also be a good time to check your alignment and inspect the rest of the driveline
Post Options Post Options   Thanks (0) Thanks(0)   Quote pickupman96 Quote  Post ReplyReply Direct Link To This Post Posted: June-01-2008 at 9:35pm
Its 2 inch. I have the shaft out to do the strut bushing and I need to pull the motor to do the rear main. I know the aligment was off so Im going to need to do that. I guess its time to use the search function
