Packing and strut bushing |
pickupman96
Newbie Joined: May-04-2008 Location: United States Status: Offline Points: 28 |
Posted: May-31-2008 at 3:16pm |
Sorry for the stupid question but my micrometer broke. What size packing should I be getting and what is the size of the strut bushing on my 76 mustang 302 velvet drive. Thanks alot and sorry again
1976 Correct Craft Mustang 17, 302 Ford
no such thing as a stupid question, 3/16's packing? 1.125 strut bushing? for a 1" shaft
pickupman96
should the shaft be 1"
pickupman96
Also I need the rubber hose that connects from the brass in the hull to the packing nut. I found where the water is coming from!!!!
pickupman96
anyone?????
well, it looks like your informing us that you found the leak and that you need a hose?
pickupman96
I need the hose I dont know if its a special hose or what because it feels soft and flexible. I dont know it thats from the oil in the bilge or what
it is marine grade hose, i think 1.5 or 2.0, you'll have to measure it or measure the area where it attaches. your gonna have to pull the coupling and what the heck it would also be a good time to check your alignment and inspect the rest of the driveline
pickupman96
Its 2 inch. I have the shaft out to do the strut bushing and I need to pull the motor to do the rear main. I know the aligment was off so Im going to need to do that. I guess its time to use the search function
