How do I... |
almabes ![]() Senior Member ![]() Joined: March-20-2008 Location: Acworth GA Status: Offline Points: 263 |
![]() ![]() ![]() ![]() ![]() Posted: April-24-2008 at 6:44pm |
Sorry if this has already been covered, but having never waterskied in my life I don't know.
What is the correct way to attach a ski rope to the pylon in my Martinique? Is there any special knot or something I should tie for saftey's sake? Thanks in advance, Anthony |
Tim D ![]() Grand Poobah ![]() Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
Through the loop, back over the top of the loop and through the loop again and attach to the little post.
Tim D
KennyA ![]() Groupie ![]() ![]() Joined: May-21-2008 Location: United States Status: Offline Points: 83 |
Just out of curiosity. What is the design philosophy behind the ski pylon? Anybody know the history?
Kenny <>{
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6119 |
Don't know the whole story, and I am sure someone can provide a more complete story than I (Brian??) but I think the basic idea was to put the pull ahead of the center of gravity of the boat so there would be no side to side pull of the boat.
I agree with Larry. The use of pylons may have started at Cypress Gardens. With multiple skiers behind the boats of the day, the center pull allowed the tow boat to make the turns. A rear pull holds the stern in place making turning difficult.
bkhallpass ![]() Grand Poobah ![]() ![]() Joined: March-29-2005 Location: United States Status: Offline Points: 4723 |
I don't know this one Larry. Also, were talking about two things here. Someone figured out that center tow point was the way to go before the pylon became the chosen form of the center pull. My Dad's 58 Wood Runabout. had a wishbone bar that attached to floor, and each gunnel and swooped above the motor box to provide a central tow point. Would be interesting to learn how it all came about. BKH
Livin' the Dream
After thinking about the question, I came up with this...
Has anyone here ever had to figure out a "weight and balance" for a light aircraft? Hopefully this makes sense... The placement of the ski pylon has to do with leverage around the center of gravity. Having the skier's various pulling forces transmitted to the boat slightly forward of the boat's CG actually helps turn the craft, or at least doesn't impede it as much as having the forces aft of the CG. In a turn, the rudder will be pushing the tail to the outside of the turn. The pylon, forward of the CG, rotates opposite of the rudder. Also, because the pylon is close to the CG, relative to the rudder, if the skier goes to the outside of the turn the effect on the amount of effort to overcome the adverse yaw by the rudder is lessened. Design was probably dictated by necesity. The loop and finger is an easy method of ensuring a secure connection that won't overstress the rope. |
Almabes, intuitively makes sense.
I knew a guy in the early 80s who completed his Master's thesis in physics around a study of the forces exerted on the pylon. Both he and his wife were national caliber skiers, and he enlisted most of the best skiers of the time including both LaPoint brothers to take measurments and do testing. I can see his face, but can't even think of the name now. Would be cool to see a copy of that paper. BKH |
Livin' the Dream
The width of the wake is also considerably different because the tow point is farther forward and makes it easier to take the two as a single occurance,
Keeping a boat straight in the course is also much easier with the force component the skier provides perpendicular to the boat not haveing a large moment arm in relation to the center of rotation of the boat. There are obvious benefits to keeping the rope out from under the boat when turning to pick up and align skiers as well. Life is alot easier with a pylon. |
It was similar to that Pete. However, it attached to the chrome air scoops on the side. BKH
Livin' the Dream
