  New Posts New Posts RSS Feed - Prop install ?
Prop install ?
mycatwon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mycatwon Quote  Post ReplyReply Direct Link To This Post Topic: Prop install ?
    Posted: June-30-2008 at 8:57pm
What should the nyloc nut be torqued to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-30-2008 at 9:43pm
Tod, As long as the nut is a brass Nylock and NOT a stainless it's fine.
I've never really seen a torque spec. on the nut. Just make sure you taper is ok.
abolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abolton Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2008 at 10:46pm
The nut they gave me covers the hole for the cotter pin. What should I do???
Get a castle nut?
Get a shorter nylock nut?
Drill another hole behind the nylock nut?
ABE
nuttyskier2002 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nuttyskier2002 Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2008 at 11:08pm
Get a castle nut?
If you have enough thread left use a jam nut with the one they gave you.
Former boats:
88 Ski Centurion Tru Trac II
59 Chris Craft Capri (woody)
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2008 at 12:12am
I would use a castle nut . If you were to remove the lock nut to many times ,like for testing props ,the nylon wears out . My question is ,,how many times can you remove a nylock nut befor it is worn out ? Do you feel like taking the chance of it being worn out the last time you put it on . A castle nut is much more mind easing, in my opinion .
Pat
My 72 Skier
Rock River
Dixon,ILL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2008 at 12:46pm
nylock nuts are for a one time use unless you are a CCF guy or like me, you could put a stainless washer on there and maybe the castle will line up in a different spot, i would imagine somewhere that there is a torque spec for a 3/4 10 thread, my torque is tight as you can get it by hand and no 4x4's between the prop and the hull
