Replaced the Pro-Tec system |
Post Reply | Page <12 |
Author | |||
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Online Points: 3357 |
now you know. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11050 |
Hi
I'm hoping there is a picture attached here. It shows a 600 Holley marine carb primary throttle shaft on the right. It has 3 grooves at either end where it rides in the throttle plate, no seals. It acts like a labyrinth seal. The other is a non marine 390 Holley, just a smooth shaft. It took me way longer to get the picture and get it on here than it did to get the shaft out to show the difference. Keno |
backfoot100
Nice comparison KENO. The marine throttle shaft also looks like it could be made of a different material, however it could just be newer and cleaner. I don't recall if it is a different material or not, but it wouldn't surprise me if it is. The splines are definitely marine specific.
Eddie |
Hi
The marine one is brass and the car one is steel. The brass one only looks good because of a wire wheel. The car one was cleaned with a wire wheel too, didn't clean up as good though. Keno |
horkn
Bringin' the RAAAARRRR, huh? Simmer down skippy. Good thing my throttle plate is from the marine carb then. In my case, yes, that was enough to make it marinized. LOL It STILL is price gouging. I looked last night in Summit's catalog, and the marine 4160 in the same cfm range was 200 dollars more than the automotive one. Thanks for the comparison shot KENO, posting a pic does a lot more than shouting out that someone is wrong. That really does make sense. Now I wonder why the marinized versions of the edelbrock carbs are not much more than the auto ones. Maybe Edlebrock isn't into gouging as bad? I actually understand Holley carbs though, unlike edelbrock carbs. |
eklock
Newbie Joined: July-09-2005 Location: United States Status: Offline Points: 14 |
The flame arrestor has never been removed. I've simply concealed it's unsightlyness with a finned aluminum cover. The boat is fully USCG compliant. |
81nautique
Could be because they probably build and sell a ratio of 100:1 auto versus marine carbs. Maybe you're right and they're gouging but the choice is yours to buy either brand so why complain about something you can't change? And just my opinion but I think your signature bash on Correct Craft is in poor taste. If the newbie with the picture of the hot babe had to change his then yours should surely go too. |
horkn
I am not really familiar with edelbrocks, so I went and found a local carb guru and I got a marine like new holley for a lot less than either a new edelbrock or holley marine carb. I love my CC. I spent a ton of hours and $$ making it how I wanted it, but I surely was not happy to find that the battery box drain was glassed nearly completely closed from the factory. Beside that flaw, it has been very good to me outside of normal maintenace on a boat that is 30 years old this year. I am sure you can appreciate that. If anything you drew attention to it so that I realized I had a fat finger typo. It is fixed now. |
81nautique
I'm not gonna argue with you but when I read your signature I read "No Class". You could change that in a second but that's up to you. Goodbye. |
lewy2001
Hey 81
Congrats on your boat being selected as the feature boat. Very nice job. Especially like the silver screen surround is it just polished aluminium or anodised. |
81nautique
Thanks Lewy2001, That was a nice surprise, The windshield frame is polished aluminum. |
horkn
Perception alters reality. My statement is not a bash, and never was intended on being one. I am sure you understand as well as I do that these boats take a lot of time and $$. It is too bad you wanted to get off on the wrong foot. I am sure I will see your boat sometime in WI, as most of the boats in IL end up in WI at some point. So I really don't think a goodbye is necessary. Also, I like this site a lot since it is pretty much the only site for older nautiques. So I won't be going anywhere. |
