"Wildman" floor replacement..pics |
62 wood ![]() Grand Poobah ![]() ![]() Joined: February-19-2005 Location: NW IL Status: Offline Points: 4527 |
![]() ![]() ![]() ![]() ![]() Posted: July-06-2008 at 11:47pm |
Well, with only a few days 'til GL, I decided to replace the floor in the 68 "Wildman" 'cuda.
It had 9 pcs of 1/2" treated plywood, with lots of nasty fitting seams that were'nt even close to make the new floor from. I decided to make a template, using plywood strips that I hotmelt-glued together. Heres a pic before ripping carpet out.. ![]() Hers a pic showing the PO's attempt to keep water from getting thru the floor, into the hull , using aluminumn flashing... ![]() ..not sure how much water it kept out, but it sure "oil-canned" when walking on it! This pic shows the first portion of the plywood strip template I made (I used cardboard in the curved area)... ![]() This is the template , after making it. ![]() The template on the new 5/8" BCX plywood. ![]() And here are a couple of pics with the new floor in.....worked great, I was able to locate the battery-box and ski-pole cutouts perfectly! ![]() ![]() I think it was well worth the little extra time. I was able to replace the original 9 pcs of plywood with 5. Now, I just need to get the new carpet and trim in by Thursday... ![]() |
rleinen79 ![]() Gold Member ![]() ![]() Joined: December-16-2004 Location: New Carlisle IN Status: Offline Points: 733 |
Hmmm.....didn't something like this happen with the Skier the first year? A last minute finish? Good luck. Can't wait to see you guys in a couple of days.
Rob |
Yeah, only that time we were re-upholstering the whole interior...I must love deadline crunches? ![]() Cant wait for next weekend either... btw, who's gonna pound on your neighbors doors with loud radios? ![]() |
p/allen ![]() Gold Member ![]() ![]() Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
Steve I hope you at least have the carpet on hand . I also hope it is the right color otherwords you might have to reapolster
stang72 ![]() Platinum Member ![]() ![]() Joined: July-31-2004 Location: United States Status: Offline Points: 1608 |
Did ya make a template for the bass seats???
Nice job! I especially like your template meathod...great way to use up scrap ply.
Steve, Didn't the boat have the vinyl wall covering on the floor? Carpet or are you going original?
Pete, The original flooring was long-gone, so Im not sure what they would have used in 68? right now carpet is the quickest / easiest way to go, soooo.... |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
Steve, that looks great. I wish I was able to make headway like you.
Our '67 Barracuda had vinyl/rubber flooring. It had a bead like texture. When I pulled my Mustang apart, I found they had used scraps of that same type of flooring to secure the exhaust hose to the hull. Looks great. Keep posting pictures. |
RainDog ![]() Platinum Member ![]() ![]() Joined: February-21-2007 Location: Mke/Grn Lake WI Status: Offline Points: 1387 |
Ditto for the '62 Classic, and they also used it to suspend the fuel lines. |
Ok guys......
Pete, Good and bad... First, the good..I found a piece original basketweave vinyl flooring under the front floorboard's old carpet. ![]() Pat, got smart and had carpet on hand this time.... NO re-upholstery here! Gary, Im mounting the bass seats on the front deck with the pedal-control for the trolling motor... 68 vintage of coarse! ![]() |
