SNOB question |
emccallum
Posted: July-10-2008 at 5:59pm |
Maybe you are storing the boat with the bow too far down and the water is never completely drying/draining out. Just a thought. What about the drain from console glove compartment/cooler? I use it as a cooler (95snob), so ice is always melting and running through that drain line. Maybe yours is leaking?
weitekampt
Senior Member Joined: July-08-2006 Location: Fisher, IL Status: Offline Points: 457 |
Do you have a leak along the rub rail? My uncle's boat had leaking issues in the front of the boat and he had a small gap under the rubrail. Little silicon fixed it. We'll talk this weekend.
rleinen79
Gold Member Joined: December-16-2004 Location: New Carlisle IN Status: Offline Points: 733 |
Does anyone know if this is normal: When cleaning out my SNOB after a day on the water, I always make sure to take everything out and dry it. It seems like recently, the carpet in the bow (accessed under the observer seat) is just sopping wet. I always get in there with a shop vac and suck the water out of there, but is this normal? Once in a while I take a little water over the bow, but nothing crazy. When you take the cushions out of the bow, the front half is carpeted, with an access panel that opens to the underside, and the back half is fiberglass with a drain hole. Is it really designed to drain water onto the interior carpet? Is it coming in through the access panel? Doesn't seem right to me.
Rob |
